IslandTractor
Super Star Member
- Joined
- Sep 15, 2005
- Messages
- 16,647
- Location
- Prudence Island, RI
- Tractor
- 2007 Kioti DK40se HST, Woods BH
Bob_Skurka said:I don't know what is 'more likely' but I believe that both will roll backward easily.
It simply boils down to torque. If any tractor has enough torque to pull its front wheels up and roll backwards then it will do so in that type of situation.
Not sure that weight is not an advantage here. Think of the theoretical situation where the heavier tractor weighs 100x the lighter one but has the same HP engine. Clearly there will be a different risk to lifting the front wheels. Working back down to reality, it stands to reason that for any given set of conditions (same speed, load, hp, drawbar height etc) that the lighter tractor will be able to rotate itself over the rear axle earlier. Even if both could go over for one set of conditions there would likely be slightly different conditions (slight decrease in speed or slope of land etc) where the light tractor could rotate but the heavier one remained (barely) stable.
