Tractor Surges With Out the Choke
   / Tractor Surges With Out the Choke #11
Intake leaks will allso cause hunting.
   / Tractor Surges With Out the Choke #12
because vacume leaks lean the mix..ie.. a fuel issue.. again.. reason choke helps is it enriches the mix.
fuel delivery system is not limited to the carb. its from the gas tank tot he end of the manifold.
soundguy
   / Tractor Surges With Out the Choke #13
Try some fuel injector cleaner or Seafoam. You like have varnish built up in the jets and passages of the carb. If it were mine, I would get a can of carb cleaner that would let you soak it for a for hours or overnight. then blow it out and verify no blockage at the needle valve. Verify good fuel flow, replace the fuel filter. You should see much improvement after doing all that.
I vote Seafoam. I have actually been able to tell a difference with that product.
BOX BLADE (A58214)
BOX BLADE (A58214)
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
