tractor tire bead breaker
   / tractor tire bead breaker #11
Well it looks like I'll have another project for the shop!
   / tractor tire bead breaker #13
augercreek: l use a stright pry bar and a post driver to break the tire bead.If the tire is rusted to the rim lay the tire down and pour a bottle of classic coke around the bead.I have freed up several stuck engines with coke, and it seems to work much faster than penetrating oil.
   / tractor tire bead breaker #14
I bought one of the slide hammer bead breakers, and only on a few tires have I found it to be helpful,
and things have to be fairly recent to make work,
many of the thing I work on have had tires on for 20 or more years, there have been times the only way to remove was to cut the tire off the rim, on my 6x6 the tires had been in place for over 50 years,
I have on really nasty ones taken the forks on the tractor and lift the front of the tractor off the ground and not broken the bead on the 20" 6x6 rim, and my tractor is a 9000 pound tractor,
but I have considered some thing like the C shaped frame with the Hydraulic cylinder, I have two of the manual rim clamp units, mine say do not use impact wrenches on them, I saw a unit that was designed for impact use, but it was about $600 the way it locks looks good, I have jsut felt that the price is a little more than I want o spend for my own work,
Pneu-Tek Bead Breaker - YouTube
   / tractor tire bead breaker #15
This thread looks pretty old but thought I would add my two cents. Found a new product that should work well with breaking the bead on tractor tires. Here's the product on their site, BeadBuster XB-550
   / tractor tire bead breaker #16
This may sound crazy, I've used a tire hammer for thirty years...
   / tractor tire bead breaker #17
I generally place the tire on it's side under the front bumper of my Land Cruiser, put the base of my hi-lift jack next to the rim and jack the front of the Land Cruiser up. A few times I've had to change the tire while on the tractor, just set the jack to pinch (use the attachment at the top of the jack), place the jack so it grabs both sides of the tire and work the handle. One side or the other will give. Try a board across the rim to get the remaining side. Tough to do by yourself, two people is fairly easy.
   / tractor tire bead breaker #18
This worked for me when a tire went bad on my tire guy's day off.
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
Year: 2011 Make: Nissan Model: Sentra Vehicle Type: Passenger Car Mileage: 161,039 Plate: Body Ty... (A55853)
Year: 2011 Make...
Anderson 31ft T/A Flatbed Equipment Trailer (A51691)
Anderson 31ft T/A...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2017 Ford F-150 Pickup Truck (A53422)
2017 Ford F-150...
