Tractor Tire Repair advice
   / Tractor Tire Repair advice #11
Don't laugh... and I'm sure no tire expert.... But out of desperation .... after an internal patch that left a gapping hole in the rubber with the patch
exposed........ I filled it in with Shoe GOO.... and it's held for 2 yrs so far!... good luck!
   / Tractor Tire Repair advice #12
i'd tube the tire, and if the gash is more than half way thru, and NEW.. see about sectioning it. otherwise a large 6" farm patch on the inside and lace the outside with bailing wire stitches.
don't laugh.. lots of farm tractors wear shoes like this.
i've seen a tire BOLTED together with an external piece of tire as an outter patch.. :)
   / Tractor Tire Repair advice #13
I was in the tire business and how I fixed tractor tires with big holes or cuts was to but a large boot over the damage spot. then take 1/4 stove bolts and drill holes about six inches out from the bad spot and put 8 to 6 or so to hold the boot in place at the same time tying the boot to the wall of the tire. make it like sewing a patch over a hole in a pair of pants. got a 3000 ford that i fixed a tire bach in the 60's and still holding and running. so it can be fixed. foam i dont think so.
All of these things are just what I wanted to hear!
I have a tire I just gashed.
I've tried 3 different places locally, all say, "Oh, no, that tire is junk. Can't fix that. $400(or up to $600) please for a new one."
I knew there had to be a way to fix it. My dad talked about "vulcanizing" tubes back in the 50's and 60's. But I've read you just about can't find anyone to do that anymore. Maybe a truck recapping place, MAYBE.
So with a 2" cut all the way through, what are the suggestions?
   / Tractor Tire Repair advice #14
I think a boot and a tube might hold it but vulcanizing a patch in place will permanently fixit. Dont know if those places are still in business though.
   / Tractor Tire Repair advice #15
That's what I'm finding out Gary.
I think I have some 3/8" (or so) thick conveyor belt. Would a section of that do for a boot?
   / Tractor Tire Repair advice #16
I would be real careful when trying to seat the tire afterwards. That's usually when it'll see the most stress. May not be high pressure but there's lots of air in their and it will have lots of force behind it.
   / Tractor Tire Repair advice #17
There are a few vulcanizing tire repair places still around. If you have a 4x4, rock crawling or off road racing club in your area - I guarantee they will know of someone who repairs tire gashes.
Another option might be to search and or post on one of the off road forums. This would be more of a needle in a haystack approach - finding someone close.
Hope this helps.
   / Tractor Tire Repair advice #18
so that 2" gash goes all the way thru?
i'd put a 6" farm patch on the inside of it at run it. with a tube
if it grows.. lace it..
   / Tractor Tire Repair advice #19
I noticed that very few tire shops have any experience with tractor and other machinery tires, probably owing to the fact that many if not most owners of such vehicles tend to fix them on their own. Last I dealt with one such shop about fixing a Trac-Loader front tire on one of my tractors they told me using a patch would affact tire balance and make driving "uncomfortable". Excuse me? This is a tractor we're talking about pal, not a Mercedes-Benz. Even with brand-new tires it barrels down the road at 26 mph with a tail wind, bounces all over the place, throws me 10 inches off my seat when I hit that nasty little hump at the intersection (must be the reason why tractor cabins are so high), and he's concerned about comfortable driving? :steeringwheel:
   / Tractor Tire Repair advice #20
You should add this to the list of stuff Shoe Goo can fix. You'll find it on their website and it has at least 1,000 entries. Personally I use it to permanently stick components to printed circuit boards that keep coming off in cold temps, ranging from tiny condensers to an 11 lb induction coil on a subwoofer crossover.
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
48" Skid Steer Pallet Forks  (A52384)
48" Skid Steer...
NEW Wolverine Fixed Mini Excavator Thumb Attachment (A53002)
NEW Wolverine...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
