Tractor tires
   / Tractor tires #1
emernst
Texas
2000 Kubota M4900
I am a rookie tractor owner with a leaking rear tire. I am sure it is not a simple task to remove and repair this tire. Would I be better off taking the tractor to a repair shop, or buying the tools and tackling it myself? Also, is there any tire sealer that can be used with the water in the tires?
   / Tractor tires #2
emernst, that's a tough question to answer without knowing anything about your experience or knowledge of tires. It it has water in it, I suspect it will have to be broken down and patched whether it is a tube or tubeless tire. Have you ever broken down a tire and patched it before, or at least watched someone do it? Did you put the water in it, or did you have it done? How often do you have flats? If it's a rare occurrence, it might be cheaper to take it to a repair shop than to buy the equipment to do it.
Bird
   / Tractor tires #3
9/17
I successfully repaired an 11.4x24 ag tire with fluid, using a stitch-it-in type patch kit (about $5 or so). Using the provided screwdriver-sized "needle" (looks like a screwdrvr with a large eye in the end), you push a piece of vulcanizing material into the hole. It seals itself thru Chas Goodyear's chemical miracle and you're done.
Unlike using same on something like my 911 with its 162 mph capability, the safety risk from such a repair is small, IMHO.
Consult a tractor dealer if necs but the kits are available from all kinds of auto and hdw stores. Get one for the kind of tire you are repairing and work with the puncture above the fluid level! If your booboo is too large and/or your tire has collapsed its bead, leaking big time fluid, well, above my pay grade.
[I did not see Bird's post until mine went up, ditto on his cautions]
Jim
<P ID="edit"><FONT SIZE=-1>Edited by jgh on 9/17/00 12:33 PM.</FONT></P>
   / Tractor tires #4
James, your repair method is only effective on a tubeless tire and is very fast, effective and inexpensive. It will not work on a tire with tube installed.
Chuck
   / Tractor tires #5
I have plenty of mesquites, prickly pear, and other assorted thorn bearing brush on my place. I use a goop called Super Seal Formula 100. It has several slang names that I won't get into here. They make a neat device to put the stuff in with. It's a piece of about 2 in. PVC pipe about 12 in. long. At one end is a cap with a short piece of air hose attached and a chuck at the end of the hose. On the other end of the PVC pipe is a screw in plug, with a fitting on top like a valve stem. What you do is unscrew the cap and fill the pipe with the Super Seal goop. Screw it back on and remove the valve core from your tire. Attach the air chuck end to your tire and apply air to the valve stem fitting. Presto, the stuff gets shot into the tire. I hope I explained that right. At any rate, I have used it on tube and tubeless tires with good results. According to the label it can be used on tires with water, and with or without sodium. Although they sell smaller bottles of it, I usually get it by the gallon jug. It runs about 16 to 19 dollars depending on where you get it. I guess the stuff eventually dries out, because every few months I'll see a tire going down and have to give it a retreatment.
   / Tractor tires #6
emernst,
Breaking down a tire w/ a iron bars or other means can a job./w3tcompact/icons/frown.gif
If you the tire doesn't have a tube you might conside now the time./w3tcompact/icons/wink.gif
Even with my father new and old tractor its a heck of alot easier to remover the tire and have Goodyear patch or replace,/w3tcompact/icons/wink.gifand if you figure out the the time and tools plus patching the cost is well worth it./w3tcompact/icons/shocked.gif
Be carefull if you should attemp this task.
Thomas..NH
   / Tractor tires #7
ErnieB, I'm glad you described that PVC device for putting stop leak in tires, because I have a home made device just like it that I've used both for stop leak, and that's how I put the antifreeze in my rear tires before adding the water. The only difference is that my home made one is bigger (18" long) so it'll hold more material at a time and the chuck has a chuck clip so it'll stay on the valve stem (yours may have, too).
Bird
   / Tractor tires #8
I beg to differ, using such a fix on a tractor tire is terribly dangerous, my L35 does have a top speed of 162mph and I would never endanger myself with such a patch job.
This idea is........
oooooooh...... uuuuhhhhhhhh......
My L35 has a top speed of 16.2 kph.
Uh....never mind/w3tcompact/icons/smile.gif
del
   / Tractor tires #9
9/17
Chuck, your limitation sounds logical. Obviously the tube would have to be patched. The tire I used it on was indeed tubeless, and the fluid was glycol (poisonous? not sure, but most folks in my area are using Methanol now, less of a problem since it evaporates quickly on escape from the tire).
Some guys are still using CaCl2, which usually means using a tube to avoid corrosion.
Jim
   / Tractor tires #10
9/17
Del, ole buddy, with the brakes you've described I do believe I would invest in training wheels, so that when a tire blows, you can stay upright while coasting to stop.
/w3tcompact/icons/laugh.gif
J
ps-seriously, how are your brakes doing? Did you ever figure out the problem?
<P ID="edit"><FONT SIZE=-1>Edited by jgh on 9/17/00 10:12 PM.</FONT></P>
(2) ROLLS OF HD CHAIN LINK MESH WIRE (A50460)
(2) ROLLS OF HD...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2013 Ford F-150 XLT - EcoBoost, Blown Engine, Good Parts Truck (A51039)
2013 Ford F-150...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
