Tractor Weight?
   / Tractor Weight? #1
SteveInMD
Platinum Member
Brookeville, MD
TC33D
I'd like to buy a trailer for my TC33D but I can't seem to find the weight info. in the operator manual or on the NH web site. I've got a TC33D will CaCl filled rears, a 7308 loader, and a Woods 7500 BH. Can anyone tell me what this rig or any part of weighs?
   / Tractor Weight? #3
7308 loader with mounting brackets weighs 590#.
   / Tractor Weight? #4
Loaded tires adds ~800#? (educated SWAG)
Backhoe weighs 1,000#
Grand total 5,000#
You'd be about at the limit with a 7,000# "Car hauler". Keep in mind that trailers are rated at GROSS weight. You need to subtract the trailer itself to get your NET capacity.
   / Tractor Weight? #5
I have basically the same set up as you with the exception of the filled tires as I have wheel weights and I ended up with an over kill 12k tilt trailer. I was really looking for something a bit less but the dealer gave me a real good deal. Personally I'd look for something with brakes on both axles, non passenger car tires with a bit of a fudge factor on net weight capacity.
   / Tractor Weight? #6
</font><font color="blue" class="small">( Grand total 5,000#
You'd be about at the limit with a 7,000# "Car hauler". Keep in mind that trailers are rated at GROSS weight. You need to subtract the trailer itself to get your NET capacity. )</font>
Good point. A 'standard dual axle car hauler with 1 axle of brakes, and a wood deck is going to weight about 1700-1800 easy pounds depending on ramp setup, and the amount of 3" or 4" metal used.
Soundguy
   / Tractor Weight? #7
I'm glad too see this post. I'm in the same boat. I have been looking a trailers and may get one fron Northern rated at 7,000lbs. I have a TC-30 with filled R-4s and a fel. I have estimated this weight at around 3,700lbs without attachments.
My concern now is the capacity of my pickup. I have a 2001 Chevy Silverado extended cab 4wd 1500. It is rated to pull 8,000lbs. I like to have an extra fudge factor but it seems my set up is going to tax my pickup. I would appreciate any input.
   / Tractor Weight? #8
I enjoy antique tractor pulling and regularly max out my 18 foot 7000lb "car hauler" behind my GMC 1500 with the 5.3 which is rated for 8000lb towing. I didn't want to feed a 6.0 as a daily driver, and Diesel doesn't fit my needs. All kinds of power, and with brakes on both trailer axles, plenty of brake, too. It fits my needs, and I am very happy.
   / Tractor Weight? #9
<font color="blue"> it seems my set up is going to tax my pickup. I would appreciate any input </font>
I pull my TC18 setup (about 1,000# lighter) with my 1/2 ton Ford 5.4L V8 no problems. As Rick said, brakes on both trailer axles helps.
   / Tractor Weight? #10
</font><font color="blue" class="small">( My concern now is the capacity of my pickup. I have a 2001 Chevy Silverado extended cab 4wd 1500 )</font>
You should be fine. A full size pickup with correct hitch,and a car hauler that is within rated load and has at least one axles of brakes is a good 'fit'.
My dodge 1500 4x4 5.9L handles my 16' car hauler and tractor fine. I'm not sure what my ex-NH1920 and mower weighed, but had to be getting close to capacity.
Truck never strained, and having an axle of e-brakes was great .. 2 axles would have been icing on the cake.
My yukon 4x4 with 5.3L engine pulled the same setup a tad better, as the yukon weighed a bit more than my dodge.
Soundguy
2015 Kubota KX91-3S2 Mini Excavator (A55973)
2015 Kubota...
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
DOOSAN G25KW GENERATOR (A58214)
DOOSAN G25KW...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
Spirit scooter (A55787)
Spirit scooter...
