Tractor wheels and bolts, not studs
   / Tractor wheels and bolts, not studs #11
daTeacha said:
VW includes a plastic threaded stud to put in one bolt hole when remounting wheels.
I sure wish my VW came with one of these things, lining up holes and putting in bolts is a hassle. :( I am not looking forward to having to remove the wheels on my tractor, I know it is just a matter of time.
Villengineer said:
Usually difference is between using the studs vs the hub to center the wheel and carry the vertical load. If the wheel is located using the studs the nuts need to have the "acorn" shape and wheel needs to have a counter-sink to match
Good point. On my hobby car, I have those lug nuts for aftermarket wheels where this isn't the case, and they're a real PITA. But gotta do it to have Centerlines. At least, this was my thinking when I was 20 years old and was into the car. Now it just sits around lonely because I'm too sentimentel to sell it. :(
   / Tractor wheels and bolts, not studs #13
Rayco,
Sorry you took offense at me calling your tractor a mower, as I often call my tractor a mower, and even refer to the guys pulling 20 foot batwings down the highway as "mowers". It isn't the size of the tractor that makes it a mower, but more of the implement that it is pulling. If it is cutting grass or brush, it is a mower to me.
David from jax
I didn't really take offense. :)
   / Tractor wheels and bolts, not studs #15
Mine is (was, I sold the car) in the plastic pouch with the screwdriver, etc. located either in a bin on the side of the trunk or with the jack and spare tire. The car is a '98 Passat. The wheel locator stud doubles as a handle for something else, if I recall correctly.
   / Tractor wheels and bolts, not studs #16
Glad Rayco isn't mad at me, cause I make enough enemies on purpose, without adding more when I don't mean to.
David from jax
   / Tractor wheels and bolts, not studs #17
Don't worry, the Kioti's rear wheels have 2 studs and the rest bolts, so
mounting is not bad. Like the B3030.
It seems Euro cars are mostly bolts, while American and Japanese use nuts/
studs. My BMW and Ferrari were all bolts. I like how VW provides a guide
stud...that't the first I heard of that.
   / Tractor wheels and bolts, not studs #18
My Mahindra (TYM built) has one stud per wheel to ease mounting a bit, the rest bolts. I see no reason why someone with an all bolt wheel can't install one stud and leave it there - then you would have 4 spare wheel bolts for when you lose one or ruin one. Just be sure the nut is the proper type for your wheel i.e. flat or conical.
   / Tractor wheels and bolts, not studs #19
Are all conicals the same? I ask because I got some 16" Ronal wheels for the 'dub and they came with their own bolts along with very strict instructions to use only those bolts.
BTW, if anyone wants a good deal on the wheels and a good set of Goodyear triple tread tires, PM me. They fit '98 and later Passats and Audi A4's.
R&G Trailblazer 1000Gal 28% Applicator (A52349)
R&G Trailblazer...
Bush Hog 176 3 pt Blade (A50514)
Bush Hog 176 3 pt...
2022 Wacker Neuson SM100 Mini Skid Steer (A52128)
2022 Wacker Neuson...
UNUSED MOWERKING QUICK ATTACH BRUSH CUTTER (A51244)
UNUSED MOWERKING...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
