John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,045
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
I am by no means trying to claim that GOL is the only way to address every situation. I don't cut the big stuff in the Pacific NW, nor am I ever likely to. I don't presume to say I know the best techniques to take down a 4+ ft diameter tree in a tough situation. Around here, I have little use for that knowledge.Depending on where and who’s ground you’re cutting on out here back strapping in front of the wrong manager can get you sent home. Is there a time and place to do them yes but it also places a lot of tension on the back of the stump that can rip out with a gust wind. I remember when I broke in under some of the old growth guys the saying was it’s just hardwood chair it out and with our Alder out here you look at it wrong it’ll chair out. We also fall a lot with what’s called a lead so you will fall stuff 90 degrees or so from a lean. You say soft faces Dutchman that’s an interesting topic I’m not sure how that would be fine able by OHSA being it still uses full hinge there’s no by pass cut made it’s just cuts into the stump as reliefs.
I may have misspoken with the "soft dutchman" comment. What I meant to refer to was any technique that requires you to remain at the stump while the tree is falling as you make cuts to redirect the fall. The OSHA and insurance folks have a cow about that sort of thing, which is why you don't see it taught in any of the Logger Certification classes out here (though I'm sure there are plenty of people who actually use those techniques here.)
