Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #25,561
You're in MO too! Too bad I didn't know you wanted it. I had a dumptruck load of BIG Hedge trunks hauled out of here a couple of years ago.
I have my share of Locust also.
My back says you can keep those big trunks.
   / Tractors and wood! Show your pics #25,562
Now honey locust on the other hand............
I got some honey locust a couple years ago, very very heavy, but I enjoyed burning it. Very hot fire, long lasting, no complaints, except maybe the weight. & Normally I'm burning Red Oak!
   / Tractors and wood! Show your pics #25,563
It actually burns really well and splits easily I just don't care to deal with the sometimes 8 to 10" thorns. Usually I save it to split when removing them on the property but let it lay for a year. Thorns come off much easier after a year on the ground.
   / Tractors and wood! Show your pics #25,564
We received the tree from a tree service, no thorns, just trunks. Not sure how or why, but no thorns.
   / Tractors and wood! Show your pics #25,565
Now "THAT" is a seriously nasty looking piece of wood to need to deal with!!! Even to burn it looks like lots of hand punctures!!
   / Tractors and wood! Show your pics #25,566
Black locust usually has little to no thorns. I split a lot of it as well.
   / Tractors and wood! Show your pics #25,567
Tree guy said honey, but it also may have been on the ground for a few years.
   / Tractors and wood! Show your pics #25,569
Good day procuring some firewood. Bout half tank of fuel burned in the tractor skidd'n and pushing up the pile. 3/4 gallon of saw gas used threw the 372 xp.
   / Tractors and wood! Show your pics #25,570
New Project:
The 2520 didn't have much to do yet, just carried my gear.
The job is removing two small, dead elms next to the evaporation pond. The larger one on the right is 10" on the stump and about 30' tall, the one on the left is 8" on the stump and maybe 25' tall. The circle at the top shows that the top of the larger tree had grown into the walnut tree above and the circle at the bottom is a small hackberry that I'm trying to preserve.
There are also trees on the back side of these two that I did not want to damage, so I decided the best course of action was to climb the bigger tree which allowed me to de-limb and cut the tops off both trees.
This picture shows my climb line set in the bigger tree and it's tied off on the base of the trunk of the smaller tree adjacent.
Note: Normally, you would do your "base tie" on the same tree you are climbing, but there were too many branches in the way so the line wound up going behind a branch on the small tree and it was too hard to move so I just tied to the small tree. This was not ideal because it was kind of torquing on the tie-in point but I knew the bigger tree was still in pretty good shape, so wasn't real worried about it snapping off.
Being tied into the bigger tree allowed me to swing back and forth to de-limb both trees with just one climb.
Next picture shows the tops and limbs removed and just the main stems left standing. The rest of the branches are on the trail on the other side of the berm behind all the bushes. Ran out of time this day, so will drop the stems chip branches and haul the bigger wood to the wood pile next time.
For those interested in the climbing setup, I'm using a Buckingham Master 5.0 saddle, Yale Blue Moon climbing rope and a Rope Wrench with Hitch Climber pulley and friction hitch for support. Also using a Notch Jet Step foot ascender and a Haas Velox knee ascender for moving up the rope.
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A55851)
Miller Trailblazer...
CATERPILLAR 242D SKID STEER (A52707)
CATERPILLAR 242D...
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
1997 Chevrolet C3500 Auto Crane Service Truck (A55852)
1997 Chevrolet...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
