Tractors whines but won't start
   / Tractors whines but won't start #1
TheWizardofTN
Ford 4 Cyllinder
Hi,
I have an older Ford 4 cyllinder tractor which starts by turning the ignition 1/4 turn, then putting the gear shift in the start position.
I was running it this morning, turned it off, then back on, and it made a whine but then nothing when I engaged the gear shift.
I started checking electrical connections in case something had shifted, and found that the connection between ignition coil and distributor was just a loose wire. I've replaced that and it still doesn't start.
Should I be thinking 'starter,' or something else?
Thanks!
   / Tractors whines but won't start #2
If I understand you, the starter is spining, but the engion doesent turn over. You most likly have a starter problem. It could be the silinoid, or the bendix spring on the starter gear. If you tap the silinoid, it may start.
David-Davies
   / Tractors whines but won't start #3
Hi, I have an older Ford 4 cyllinder tractor which starts by turning the ignition 1/4 turn, then putting the gear shift in the start position.
I've never heard of a tractor (or any vehicle for that matter) that had the starter solenoid energized using the transmission shifter. Every one I've seen has been through the ignition switch or a dash mounted starter button (ok, some foot operated ones too! :D). The only switch I've ever seen shifter-related is a neutral safety switch. Is this something peculiar to Fords? Just curious...
   / Tractors whines but won't start #4
Sounds like a starter solenoid. That is the part that forces the starter gear into the flywheel gear when energized.
Let's say that it doesn't HAVE a starter solenoid, but is old enough where it has what I suspect is a module. Where does someone go to get THAT?
2012 Chevrolet Silverado 3500 HD Enclosed Knapheide Service Truck (A52377)
2012 Chevrolet...
2005 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A54313)
2005 INTERNATIONAL...
2008 Ford Focus Sedan (A53424)
2008 Ford Focus...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A54607)
2006 KENWORTH T800...
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
