trading up to JD3720 need some advice
   / trading up to JD3720 need some advice #11
Congrats on the tractor buy. You should enjoy it. I think the cutting edge comes with the bucket, mine looks to be factory installed. Where in S WI are you from? I grew up in Ozaukee County. Go Pack :D!
NorthPole,
I have yet to run into any weight related problems with the SSQA, and as posted before the skid-steer carrier is not much more metal than the Deere QA. I have not used my 72" bucket for dirt or gravel yet; I have only used it for snow so far. Based on Deere's volume specs, the 300cx could not/would struggle to lift a heaped 72" foundry bucket of dirt or gravel to max height, even if the bucket weighed half of what it does. I use my 60" New Holland bucket for dirt work and I can still lift that to full height when heaped full of black dirt. That ends up being plenty of weight, I feel it is about enough with loaded tires and either the hoe or a 1000# box blade for ballast.
The JD Worksite Pro bucket is probably around 150+ pounds heavier than my 60" bucket. I can push the NH bucket around the shop floor by myself, not so with the 72". That is one deep and well constructed bucket, over kill for a compact tractor, but very nice. I'll be using it mostly for snow, mulch, debris, and other loose materials, so the weight is a non-issue for me.
Brodhead area in Rock county. I've got 40 acres in Richland county, that's where I'll be working the 3720 the hardest ;-) Snow and mowing at home also.
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
2011 Ford F-350 Knapheide Service Truck (A54814)
2011 Ford F-350...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A55301)
2020 Massey...
