Trailer Brakes
/ Trailer Brakes #1
Phred
Veteran Member
Arkansas
TN70D, 4wd, 16x16 trans
How big of a trailer can one haul without trailer brakes?
I am thinking about hauling a ~ B21 sized unit with FEL and 4’ cutter about 30 miles. I have a diesel F250 (manual 5 spd, ~7000 lbs) and my thought is that if I go slowly and carefully this should be a piece of cake. Since the trailer should be at least ~1500 lbs lighter than the truck even the Ozark hills should not be a problem?
I have seen guys pull these with gas powered F150s, however, they may have had electric brakes. But then again I have seen a lot of people do a lot of dumb things…….
So for those of you with lots of experience in these matters what do you think?
Ok, marginal, unwise, or really Dumb?
Also I am not planning on doing this more than a couple of times a year, so is it worth while to invest in a brake controller?
Phred
/ Trailer Brakes #2
I don't think you'd have any trouble with load Phred. The main thing you want to do is when you are going down hills just keep her slow and slow down before you speed up. It's easy to get them going too fast and brakes burn up in a BIG hurry going down hills. I learned that the hard way when I was 17 years old. Hauling a load of cattle down a steep hill and even though I'd heard it a million times I was in a hurry. Burnt up my brakes a little over half way down. If you don't think that is a pit in your stomach! Luckily there was a straight away at the end of the hill and I just held it straight. I was hitting about 90 at the bottom of the hill with a load of cattle behind me. I NEVER made that mistake again.
/ Trailer Brakes #3
Fred as CBD said it should be marginal ok to do if you take it slow. Also I think it would be wise to get the brake controler. They will run about $50-75. And most all newer trucks already have the hook-up pre-wired under the pannel. You just plug in your controler and that is it. Should take less that two hours to wire the whole thing if you had to... And makes it a lot safer, and lets you haul a lot more without a problem. My controler is made by drawtite, and pluged right in, but had to run a wire back to the trailer connection because some had already messed up the wire harness before I got the truck..
/ Trailer Brakes #4
Better safe than sorry. The cost of a brake controller is trivial compared to what it could cost you otherwise. In NYS, I believe the point at which brakes are required is 1000 lbs. Also, brakes are required on 80% of the axles. That means that brakes are required on both axles of a dual axle trailer. If you are going up and down some fairly steep "hills", I would definitely get brakes on the trailer. So, if you were in NY, the troopers would cite you for what you plan on doing.
/ Trailer Brakes #5
I agree with Jag, spring for the brake controller. They aren't much money and the trailer brakes do make a difference. Also could save your wallet in the event of an accident. Some insurance companies check for brakes and overloading. I have a Reese controller for about $75 /w3tcompact/icons/smile.gif
/ Trailer Brakes #6
What year and model is your F250?? I have a 2000 F150 Lariat w/ towing package and didn't need a controller. The controller is built in somewhere with the towing package and all I had to do was install 2 relays that were in the glove box into the fuse/relay box under the hood and "presto" - but having had trailers without brakes and with brakes --- I'd always go for the "with" if there was any choice in the matter at all.
mike
/ Trailer Brakes #7
Phred,
I'm not sure I understand whether or not you have brakes on your trailer. If you do, I would definitely get a controller so you could use them. My experience is limited to surge (hydraulic)brakes, which are supposed to be better on boat trailers because of corrosion, dunno if this is true. Anyway, I would go with brakes if at all possible. I was in an unavoidable (very unavoidable) accident that was so only because I did not have trailer brakes. 60 mph, dry pavement, and a fella cut me off on a two lane bridge, braked hard, and hit the guy in front of him. My turn . . . Bam!/w3tcompact/icons/frown.gif The feeling of that boat "pushing" me along is one I won't soon forget (or the bruised ribs, semi driving over the front half of my truck, etc). I would never pull anything over 2000 lbs, personally, that didn't have brakes. Even the most careful people have accidents . . . that's why they call 'em accidents. 15 years of driving and that's my only one. Bad memory.
/ Trailer Brakes
Guys,
Thanks for the feedback.
After looking into the cost a bit more I will go with a controller.
Any suggestions on the best maker?
Phred
/ Trailer Brakes #9
Do check your state laws. Here in NH anything over 5000lbs GVW must have brakes, and it's for a good reason. As noted earlier, if you do have an accident and it turns out you were not using your brakes, you would be very exposed.
I've got a techonsha (sp?) controller and it was $70 or so in the local shop. It makes a BIG difference.
Search for brake contollers in this site. I asked about them a year or so ago and got a bunch of good advise which led me to by particular buying decision.
/ Trailer Brakes #10
Phred, I've heard Tekonsha are good. I've got a Reese, which I'm not too fond of. You'll find two major types of controllers: Pendulum and Electronic. The pendulum models sense vehicle decel and the electronic models (like mine) just use a delay. Each uses the stop light switch to detect braking but neither is truly proportional to to the tow vehicle brake pressure. I've never used a pendulum model but would like to try. I find myself tweaking my electronic model quite a bit (when going from highway conditions to parking lot conditions etc.). A decent RV dealer will have a good selection /w3tcompact/icons/smile.gif
/ Trailer Brakes #11
No doubt the best trailer brake controller out there is the ultima by Jordan Brake. They are at www.jordanbrake.com.
/ Trailer Brakes #12
Thanks for that tip Richard, I'm going to check into a Jordan /w3tcompact/icons/smile.gif
/ Trailer Brakes #13
Rob, I would stay away from the pendulum type... Most people who has used them do not like them... It can act differently going up or downhill also mounting can be a problem with some. Most electronic units have a dial for controling delay, and amount of force (weight of load). This last is very handy because of the big difference with and empty trailer and full load.
<P ID="edit"><FONT SIZE=-1>Edited by Jag on 06/07/01 10:50 AM (server time).</FONT></P>
/ Trailer Brakes #14
Mike I believe the relays that you installed are for the brake circuit and the 12 charge line to the seven way plug in the back of the truck. You should still have a pigtail that plugs in under the dash and the brake controller hooks to that.
Then again I might be wrong.
Gordon
/ Trailer Brakes #15
People either love the DC ramp style of controller like the Jordan or hate it. It depends on driving style. If you ride your brakes at all you'll find the the trailer is doing most of the stopping and thats not good.
Same goes for the pendulum style of controller. Myself I prefer the pendulum style of controller. But thats me, having driven quite a few different rigs with different controllers, I find that the pendulum is the best setup.
Gordon
/ Trailer Brakes #16
That's what I thought too.
There was a plastic bag in the glove box with the pigtail, the relays and a sheet of instructions (that I read last of course) . I originally bought a controller, hooked it up to the pigtail that just plugs in under the dash, but it didn't work. (no power from the pigtail) So I finally read the instructions and it said if you had the towing package factory installed you didn't need a separate controller.
" Your vehicle has been equipped with a factory installed 7-way trailer tow system... If your trailer has electric brakes, simply connect your trailer to your vehicle"
I called a Ford dealer to confirm and he said the same thing (but I got the impression he really didn't know fer sure). I know when I have the tractor loaded on behind that lil' F150 I sure need the brakes on the trailer to work and they do just fine. Would they work at all without a controller? I'm assuming here that since they do indeed work that there must be something in the trucks computer that takes care of it.
I've only hauled the tractor once so far but there is no doubt that the trailer brakes were working as advertised 'cause I was going up and down hills. I sure hope my assumption is right - not a good policy I agree but all I have for now. I tried to buy a Chiltons for the truck to get a schematic - but they aren't out yet I guess.
mike
/ Trailer Brakes #17
I see two serious problems with a "hidden" factory brake controller:
1) No warning if the circuit isn't complete, an all to common experience with trailers with exposed wiring.
2) No way to adjust brake power. The controller could lock up the brakes on my 12,000 lb trailer when empty and have way to little power when it is loaded.
Pat
/ Trailer Brakes #18
Now that is a new one on me thanks for the information. That is the first I've ever heard of a built in controller. Times a changin.
Wonder why they still give you a pigtail and relays? Go figure
Also I've got the same question how can you adjust it?
Gordon
/ Trailer Brakes
“What year and model is your F250??”
Mike,
My truck is a 93. That year is pre-wired for an add on controller but its not built in.
Is hauling all but the smallest of tractors with a f150 pretty exciting (not in a positive way)?
I also own a Nissan pathfinder, although the manual claims it can haul 5000 lbs mine never will. Great four-wheel drive truck but not quite up to most pulling tasks.
Phred
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
(INOP) 2008 FORD F150 XL TRITON TRUCK (A59823)
(INOP) 2008 FORD...
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
2017 Nissan Altima Sedan (A59231)
2017 Nissan Altima...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
