Trailer building
/ Trailer building #11
Well, I am not retired anything and proud to be a wild and wooly civy and could care less anyway. That aside, I have some training and knowledge of metals and matierial strength and I am a bit confused as to why this is an issue? Most of these trailers you see are built from mild steel, probably a 1000 series alloy. I doubt it should be a concern if the trailer is sufficiently over built, fatigue life should be in excess of the remainder of your life. When the elastic limit is exceeded the metal takes a new shape--it bends, depending on the type of metal, working below the elastic limit to calculate fatigue cycle life--depends to what percent of fatigue strength the metal is worked repeatedly. If the metal is so oversized that it simply does not give then it is not "cycling" and limit life would be infinite excluding corrosion effects etc. If you want an expensive last forever trailer build it from heavy wall, 4130, chro-mo steel, seal the tubes and inject tube seal or linseed oil in the tubes and zinc chromate the exterior surfaces and then paint the hades out of it with polyurethane paint--something like Dupont Imron. That would be way overkill but the stuff has about 3 times the strength of mild steel, 30,000-50,000 psi vs 90,000-120,000 or better for high strength steel--4130 and similar high strength alloy steels. This is without reference to text, off the top of my head numbers and a vastly over simplified attemted explanation for a very involved and complicated subject I am not involved in on a daily basis. I doubt people calculate fatigue life of trailers, they just grab some chunks of steel, weld it up and say that looks about right. J
/ Trailer building #12
I agree, Larry. It reminds me of when, in my prior occupation, we had a somewhat eccentric character running the "body rebuild" shop. And I lost count of the number of times I went to him with an idea and asked whether he could fabricate what I wanted, but I think every darned time I did, he said, "Sure I can, but what about if I . . .." And you know, I think he had a better idea every time. I love guys like that!
Bird
/ Trailer building
Your post reminds me of what a Law Instructor once said to a class I attended, "The internet has opened up a whole new world, where anyone can be anything, and they will say or comment on everything just so that their voice will be heard." Thanks for the "Extra Input".
/ Trailer building
Your attitude may be why it was your previous occupation, or maybe you never quite knew where those gray areas were for you to expand on. Thanks for the "Extra Input".
/ Trailer building
My reference to "Retired Military", meant that I didn't just fall off the turnip truck, no offense to others. Thanks
/ Trailer building #16
/w3tcompact/icons/laugh.gif /w3tcompact/icons/laugh.gif
"wild and wooly civy" " could care less anyway" !! Thanks TresCrows, for the laugh, ... good place for it! /w3tcompact/icons/wink.gif
Larry
/ Trailer building #17
Gosh, Cornfed, I'm shocked /w3tcompact/icons/shocked.gif that you'd get off topic that way. I thought you didn't want anyone doing that./w3tcompact/icons/wink.gif And the reason it was my "previous" occupation was that I had other things I wanted to do, so I retired just short of 25 years in spite of them trying to talk me into staying./w3tcompact/icons/laugh.gif And yes, on this forum we do tend to get off topic, some responses to questions go far beyond the original question, and in the process a lot of friends learn a great deal from each other, and have fun doing it. I realize it isn't the best format for everyone, but hope you'll join in and enjoy it.
Bird
/ Trailer building
I apoligize, I really didn't mean to rub anyone the wrong way with any of my replies. Just sending out replies and sometimes they might cut to the quick. Andy
/ Trailer building #19
No Problem andy /w3tcompact/icons/smile.gif ,
This is a "country" road, ...little bumpy sometimes, but still a great place to be !
Welcome aboard /w3tcompact/icons/laugh.gif ,
Larry
/ Trailer building #20
Andy,
About that military-service:
I sometimes stop someone I see with a "Nam" ribbon bumper-sticker, just to say "thanks", and shake their hand.
I don't know when/where you served, but I'd like to extend the same appreciation to you. Hats off!
Sincerely, /w3tcompact/icons/wink.gif
Larry [ LHSmith @wvi.com ]
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
10 Safety Systems Barricades (A59317)
10 Safety Systems...
2011 CATERPILLAR 305.5D CR EXCAVATOR (A62129)
2011 CATERPILLAR...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
