Trailer coupler rating
   / Trailer coupler rating
Reg said:
The coupler's rating is about the towed load - NOT as you seem to have concluded, about what it can take suspended from or loaded directly onto it.
If you go through the whole trailer you will find similar mismatches in other places, e.g. the tires COULD take more or less load than the axles, typically more. You are limited by the lowest rated component - in it's role, not a fantasy role of hanging the trailer from it.
I believe what I am trying to find out is not a fantasy rating of the trailer components abilities under extreme instances but rather if the manufacturers are correct in putting lower rated components ( specifically the 5000lbs rated coupler) on a trailer rated for thousands of pounds more overall.
What would be the difference between the "towed load" and the "load directly placed onto the trailer"??
By your point of being limited to the lowest rated component ( which I happen to agree with) than it would be the wrong coupler for a 7000 GVW trailer? There seems to be a huge disparity in opinions here but I would rather err on the side of caution or am I reading your message wrong?
Thanks again for the input, Scott
   / Trailer coupler rating #12
Not all . But, most places only sell 2" 5000# rated balls. I had to look around to find a ball rated for more than 5000#
   / Trailer coupler rating #13
As much as the litigious society we live in is touted on TBN do you think it's likely that ALL trailer manufacturers use the same components in their trailers, purposely overrate their capacity, and remain in business for decades?
If you've ever moved something like a boat on a trailer by hand you can visualize the difference between towed & actual load. If the boat weighed 1500 lbs you could neither lift it nor drag it directly across the ground. When on a trailer the leverage of the tongue length makes it possible to lift the front of the trailer, a portion of the boat's weight. The bearings & wheels carry most of the boats weight and overcome the friction of dragging the boat. The hitch sees the resultant weight, not the actual weight. Even in severe braking most of the boats weight is carried by the wheels. If you run into a wall the hitch will see the full weight of the boat plus the force generated by its velocity. Then the hitch will probably fail.
Over the road log trailers in NH can be registered for 50 ton. You won't find them fitted with tires rated for 12500 lbs because the tractor carries much of the load. I looked at a new 20T tagalong trailer last night. The load capacity of the tires is just under 16T. The designed rating is based on the assembly, not the weakest part. A failure of the weakest part usually comes from exceeding the design rating thru extraordinary circumstance, like hitting the wall. MikeD74T
   / Trailer coupler rating #14
skipmarcy said:
I had a 2" Bulldog coupler rated for 10k and 2" ball & mount rated for 10k, you just have to look elsewhere than Walmart for them.
I've seen 8k 2" ball, I have one but a 10k 2", I have not seen or heard of this animal.
Got a link of who has this?
   / Trailer coupler rating #15
Sorry, I don't know where to get the 10k 2" ball online. I bought mine from a trailer supply outfit in Ft. Pierce, Fl., along with the 6" gusseted drop mount I used on my F250 to pull my tractor. The ball had the same diameter shank as my 2 5/16" ball, I think it was 1 1/4" shank. They both were stamped for 10k rating. My Hurst 20' equip. trailer had a cast Bulldog type coupler with 10k rating stamped into it, not sure if it was the Bulldog brand. I just sold my F250 and 2 heavy trailers about a month ago so I don't have them here anymore. That Hurst trailer was a 14k trailer by the way, with that 10k rated coupler. I wondered about it for awhile but in the 7 years I had it I'd hauled my tractors around thousands & thousands of miles on all kinds of roads and fields.
   / Trailer coupler rating #16
Yea that 8k I have is also 1 1/4" shank.
Interesting on what makes one 8k and the other 10k with same shank size and that 10k probably had a tapered shank from the ball to the base also.
   / Trailer coupler rating #18
there are 2 points to this. 1 is how the trailer is designed to distribute weight when properly loaded. the balancing act between weight down on the hitch vs the weight on the wheels.
2 is, what constitues resonable risk. how much must a trailer manufacturer overbuild a trailer to be reasonably safe from litigation when some one misuses a trailer and it fails. the trailers have to be built to handle some over exertions due to user error. ie 40/60 so that the toungue is lifting the tail of the truck due to load shift during use. handeling a left side heavy trailer because some one has 1 full tank and 1 empty tank on the trailer with 2000lbs of liquid in the tank. the users tendancy's to not follow the weight or load specifications are part of the "proper" build process for a good trailer or any tool for that matter.
users view of the product also falls in to play as well. some one mentioned the in writing issue and how the manufacturer just replaced all the fronts in town. it is easier for them to not have to answer those questions then to find out. it also is better to make a product the user doesnt question right off the bat.
Craftsman YTS 3000 42in. Riding Mower (A49346)
Craftsman YTS 3000...
2005 GROVE RT700E ROUGH TERRAIN CRANE (A50854)
2005 GROVE RT700E...
2023 QUALITY CARGO 16 T/A ENCLOSED TRAILER (A50854)
2023 QUALITY CARGO...
2011 BMW 5 Series 550I GT Sedan (A50324)
2011 BMW 5 Series...
2018 VOLVO VNL64T670 TANDEM AXLE SLEEPER (A51219)
2018 VOLVO...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A52128)
NEW 2022 Load...
