Trailer plug on T450 to power LED work lights
   / Trailer plug on T450 to power LED work lights
That's it !!!
Thanks for diagram...sure will beat fiddlin' with voltage tester....al
   / Trailer plug on T450 to power LED work lights #13
No problem. Did take a little searching. Good luck.
   / Trailer plug on T450 to power LED work lights #14
I have a 2014 Mahindra 5010 with the European style trailer socket. I was debating on whether to rewire a standard 7-pin rv plug until I found this item on etrailer.com. Works perfectly....... Plugs into the factory Mahindra socket and adapts down to a standard 4-pin flat which is widely used in the US. The description says it's for a Land Rover 7-pin to a 4-pin flat but it's the same plug that fits my Mahindra tractor. Hope this helps
Trailer Connector Adapter for Land Rover - 7-Way, Round Pin, European Style to 4-Way Flat Tow Ready Wiring 118710
Thought maybe I could figure out wiring to trailer plug on back of my T450 TYM to power LED lights mounted to ROPS ( but wires are SO-O-O buried )...I would like to get male plug to wire up with LED pigtails and just plug into female plug when needed. Anyone done something similar...where to get male plug to do it???
Got her wired up just fine with the plug I bought, but for some reason I only have 10.5 volts on the pin on tractor for trailer tail light that I used to power LED lights (???) Lights I got from Northern Tool work with 9-32 volts / but I wonder if I get all the lumens with the lower voltage.
John Deere 6430 Side Arm Tractor (A51573)
John Deere 6430...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52748)
Hay Van FL-95 Bale...
2011 PETERBILT 337 (A52472)
2011 PETERBILT 337...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
