Trailer Striping- How To?
   / Trailer Striping- How To? #31
I know I've learned from this thread.
Now I want to pinstripe something just so I can try out those 3M stripes. Maybe my welding cart.
   / Trailer Striping- How To? #32
I have painted and striped, cars and vans my whole life.
Painting on stripes requires the right type of paint, and good technique.
Save yourself a lot of trouble, and don't paint them, use the stripe tape.
Remove the backing about an inch, (if there is one), and place one end of the stripe, on the end of the item your striping. Unroll enough stripe to go the length of your project. Holding the tape taught, and away from the surface, remove the rest of the backing. Pull the tape straight and gently lay it against the surface. If the tape is where you want it, gently finger it down, then press hard to set the adhesive. If it is not where you want it, you can lift and reset it. Cut the ends while holding them above the surface, with a brand new razor blade. DO NOT CUT THE PAINT. Pinstripes usually have a clear protector on top called a liner. If there is a liner, peel it back with your finger, or use a piece of masking tape to lift it, and remove it completely.
Thanks Ray! Sounds great. I found a video on how to do it. And I agree with you, it will be much easier!
   / Trailer Striping- How To? #34
Good luck Bondo...you'll find with a little practice you can do a really nice job. I would use single line tape on a trailer..The doubles take a little bit more trial and error to get right on rounded stuff..Like fenders.
Ignore the rude remarks..99.9% of this site is really helpful and friendly. A little friendly ribbing happens...But hey!!!
   / Trailer Striping- How To? #35
I have tried to freehand lines in the past with really bad results, but that maybe just too much coffee. :confused:
A little tool was mentions with a wheel to apply the paint. Eastwood sells one, as do many other compainies. See their item 37024
Good Luck!
   / Trailer Striping- How To? #36
A lot of the guys that paint stripes with a brush, will still use masking tape as a guide, on the long ones.
2018 FREIGHTLINER BUCKET TRUCK (A51406)
2018 FREIGHTLINER...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2012 Chevrolet Silverado 3500 HD Enclosed Knapheide Service Truck (A52377)
2012 Chevrolet...
CAT 416B (A47477)
CAT 416B (A47477)
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A54757)
UNUSED WOLVERINE...
