Trailer too high or BH too low or is ramps too short?
   / Trailer too high or BH too low or is ramps too short?
Thanks for the ideas.. This is a gooseneck lowboy but still has a high deck I guess from the 16" wheels/ 7K axles.
First off in my sleepy stupor typing last night I incorrectly said my ramps are only 2', 45 twelve hour graveyard shifts in a row are starting to get to me:eek: . My ramps are about 4' and I am considering making ramps 1-2 foot longer only to be used when the BH is on. Secondly I am not smart enough to unload it in the field, the earth would be much mor foregiving than concrete:eek: .. I did try backing it on it still hit.
I am also going to raise front of trailer by lengthing the gooseneck about 4" so when the trailer is loaded it would sit level rather than low in front.
   / Trailer too high or BH too low or is ramps too short? #12
A set of wood ramps to extend the trailer ramps would decrease the load angle & protect the road surface. Length & height to suit. MikeD74T
   / Trailer too high or BH too low or is ramps too short? #13
Here's the idea in action.
As you can see, one plank on the ground on each side (1-1/2" thick) was just enough. I'm going to double them up anyway, in case I have to unload on a hill.
   / Trailer too high or BH too low or is ramps too short? #14
Four feet is much better than two feet! Just ask any horse! ;) I feel much better now! :)
Your solution looks really great! I may borrow that myself for when unloading conditions give my own ramps too steep a slope for the backhoe!
Dougster
   / Trailer too high or BH too low or is ramps too short? #16
Builder- Looking at his set-up I would expect the hoe subframe to hit the trailer before the rear wheels were far enough up the ramp to angle the tractor. I have the same problem with my JD4300. No problem if it scrapes a bit on gravel or dirt but for pavement I throw a 12" piece of 4x4 under the bottom of the ramp. You don't notice a 4" step when loading but when the subframe screeches accross the concrete everyone looks to see what you are doing wrong....
   / Trailer too high or BH too low or is ramps too short? #17
Make the ramps longer, or switch to a tilt deck.
   / Trailer too high or BH too low or is ramps too short? #18
wood is cheep and quick roll with it!!!!
   / Trailer too high or BH too low or is ramps too short? #19
Builder... I think I am with Pat...at first I wondered the same thing, but I think he's right about the subframe... good solution though... 4X4's are great for many things and not a huge hump to crawl over.... although I have heard of some issues when HST's are invloved..;) But that's a whole different debate...:D
   / Trailer too high or BH too low or is ramps too short? #20
Yes you are correct about the HST issues, this is an example of where they are perfect for a slow climb up an uncertain surface over a 4" hump....
Skid Of Metal T Posts (A50775)
Skid Of Metal T...
2023 Jeep Gladiator Sport 4WD SUT (A55758)
2023 Jeep...
Heavy Duty Jumper Cables (A55788)
Heavy Duty Jumper...
2007 Toyota Camry LE (A53314)
2007 Toyota Camry...
2015 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55788)
2015 Chevrolet...
2025 Wolverine SBM-12-72W 72in Sickie Bar Mower Skid Steer Attachment (A55787)
2025 Wolverine...
