Trailering in Illinois (Info)
   / Trailering in Illinois (Info) #1
MF1455v
Platinum Member
Princeton Tx.
MF 1455v
I'm going to central Illinois next week to pick up a Farmall Super MTA and a 4 bottom plow. Found out they require chains for securing the tractor. Not a problem as I prefer to use them anyway.
Need to find out if I can use straps on the plow. Also if there are any other trailering laws to be aware of in the state. Did a Google search but that's like looking for a needle in a hay stack. Texas and Oklahoma are no problem and I have a friend from Missouri says I will be good. Any help on Illinois would be great.
Here's a little back ground on what my setup is.
1 ton Dodge Diesel
32ft gooseneck with tandem 10k Dexters
I'm sure I left something out so go easy. I'm usually over the state requirements, I just want to avoid any unknown surprises.
Thanks
James
   / Trailering in Illinois (Info) #2
Straps are fine. I trailer in Illinois quite often being from Indiana. Clean rig, good chains, working lights and they will not even bat a eye.
Chris
   / Trailering in Illinois (Info) #3
If your registration in for more than 26,000 lbs be careful. I have heard of people from KY being ticketed because they had farm plates & the registration was for more than 26,000 lbs. I actually lowered the registration on my pu because of this. The fine is for not paying the road taxes & it is over $1000.
   / Trailering in Illinois (Info) #4
Farm plates are limited to 150 miles from the registration address and not valid over state lines. At least here.
Chris
Thanks for the information guys. This was exactly what I was looking for. I do have farm tags on the trailer and its rated at 20,000 lbs. Truck is rated at 18,000 if I remember right. Need to double check. I got my Class A CDL because both were over 36,000 lbs. I've never used it for anything but this rig.
Known people to get pulled over and get the truck and trailer impounded for not having a CDL for the same size setup. But then again you see utility trailers with no lights, tags and stuff not strapped down all the time down here. Go figure.
I just completed a full inspection of the trailer this afternoon. Found the battery for the emergency break away bad. Need to stop and pick up a new one tomorrow.
Thought I include a picture of my rig.
   / Trailering in Illinois (Info) #8
Me personally would run thru the night in Illinois. Never had good luck and would be better all around to not draw any additional attention
Brett
   / Trailering in Illinois (Info) #9
I've run my farm plates all over the country, just not when towing.
   / Trailering in Illinois (Info) #10
I have never heard of the chain law, but that doesn't mean it isn't there. I haul my tractor with a chains on the front, and use straps on the back to to draw up the tension on the chains. (I know it would probably make more sense to do it the other way, but the way my trailer/tractor is configured, this works better... besides if the straps were going to break, I would rather have the tractor roll into the back of my truck than off the trailer.) Anyway though, I have never been questioned, but I have also never been pulled over with this setup or given an officer a reason to start checking stuff. I also don't have as big of a setup as you, so maybe I am a little less conspicuous.
2017 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A55851)
2017 Takeuchi...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
UNUSED FUTURE 32" CAT305 EXCAVATOR RAKE (A57193)
UNUSED FUTURE 32"...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
