Trailering in Illinois (Info)
   / Trailering in Illinois (Info) #11
I don't think the prohibition against straps exists. If it did, it would have to come from the FMCSA or other Fed Dept. Because freight is crossing state lines, it becomes a question of interstate commerce.
   / Trailering in Illinois (Info) #12
I run back and forth in central IL all the time between my 2 properties. NO issues even with some odd loads. But im usually towing at or below the speed limit.
   / Trailering in Illinois (Info) #13
I have never heard of the chain law, but that doesn't mean it isn't there. I haul my tractor with a chains on the front, and use straps on the back to to draw up the tension on the chains. (I know it would probably make more sense to do it the other way, but the way my trailer/tractor is configured, this works better... besides if the straps were going to break, I would rather have the tractor roll into the back of my truck than off the trailer.) Anyway though, I have never been questioned, but I have also never been pulled over with this setup or given an officer a reason to start checking stuff. I also don't have as big of a setup as you, so maybe I am a little less conspicuous.
You need to rethink that. My BIL had one of his crews get in a head on at 60 mph pulling a BobCat with a F450. LEO said that all 3 should have been decapitated by the BobCat but the rear chains held. One on each 4 corners.
I dont want it coming off the trailer period but I would want it going the opposite way of me and my family if it did.
Think about the forces involved in a head on or tee bone accident.
Chris
   / Trailering in Illinois (Info) #14
I don't really have a distrust for straps, in fact in industrial rigging you will never see guys using chains... only lifting straps. The problem with straps is that they are easier to damage, which will seriously degrade their reliability. As long as they are in good shape, and are not around any sharp corners I personally feel safe up to their rated capacity. I don't mean to start this discussion again (as it has been beat to death here), but that is my viewpoint.
   / Trailering in Illinois (Info) #15
One thing to add, a goose neck hitch must have safety chains in Illinois, they are not required on a fifth wheel hitch.
Thanks Dozernut, I do have the safety chains. Stopped and picked up a new emergency release brake battery today and its working correctly.
Wow, Steve, looks like we are going to be in your neighborhood. Would love to meet up for a cup of coffee, but its going to be all business on this trip. Maybe next time.
Thanks for the information.
   / Trailering in Illinois (Info) #19
drop me a line when your in town, id love to get together and chat
   / Trailering in Illinois (Info) #20
Thanks, we are going to Washington Illinois. Just outside Peoria.
Small world, I was there 2 nights ago for my daughters swim meet. I live about 100 miles west of Washington in Macomb. Good luck with your trip.
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
2016 Peterbilt 597 Wet Kit Tri-Axle Day Cab Truck Tractor (A55852)
2016 Peterbilt 597...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
