trailor floor metal or wood?
   / trailor floor metal or wood? #11
I just noticed your location, Im from Tallahassee/Havana. A metal deck trailer like I have for my forklift will get so hot it will burn your hands when you touch it. Wood is better, also when you leave your chains and binders piled on the trailer, cover them!!! An old cardboard box will work temporarily. But what me and my pals do is mount a "tounge box" either a tool box,cooler or rubbermade box, to keep them dry and more importantly shaded.
jmc what is this "snow" stuff you are talking about? is it from the slurpee machine?
   / trailor floor metal or wood? #12
"My next trailer will be a wood decked tilt trailer, if there is such a thing."
John
John,
Several companies have wood deck tilt trailers. I have a 20' tilt bed made by H&H trailers. (pics in photo section, other brands/ mahindra)
George
   / trailor floor metal or wood? #13
Just thinking about the metal/wood floor thing, also. I have a 16' wood floor trailer and it's OK. However, I am having a 14K GVWR tilt/dump 20' steel bed trailer built right now. Diamond plate floor. If I have any traction problems, I will weld on some 18 inch wide strips of expanded sheet steel in the tire path on the trailer bed. Expanded sheet steel is the stuff you see used most often for the beds of the smaller landscape/utility trailers...where you can see through it, (with the large diamond shaped holes in it). I suppose you can also nail it down on a wood bed trailer using fence staples for added traction...
   / trailor floor metal or wood? #14
I had wood floor trailers for years and always thought that steel would be superior, so I finally bought one. I tried to convince myself I liked it. I'm really a 'steel' sort of guy with a pretty well complete metal working shop. In the end, I hated it. Both of my trailers now are treated wood deck trailers. Sure I have to treat them every other year, but I really like them better than steel. I guess there's something about always scratching the paint off of the steel bed with chains etc. that partly drove me nuts. I don't know, I just ended up preferring wood after I was just positive I wanted stee.
   / trailor floor metal or wood? #15
I thought that in Fl "snow" was referred to as white powder as seen in Miami Vice.:D
Derek
   / trailor floor metal or wood? #16
I own one of each and definitely prefer the wood deck trailer. Feels solid, loads good, doesn't rattle and I have not busted my tail on it yet.
   / trailor floor metal or wood? #17
What? Your tractor doesn't leak??? My old ford keeps the wood water proof better than that "thompsons" stuff! lol.
jb
   / trailor floor metal or wood? #18
I don't know, guys. I have a wood-bed trailer and steel-bed trailer. I much, much prefer the steel. When I go to the local gravel or dirt yard, especially, I find it much nicer to shovel out the material when the bucket edge or shovel end can ride against the steel deck. Also, I don't have to worry abou my steel deck warping, cracking, or just plain old breaking over time. I cannot see the day when I will have to replace it. Just my $0.02 here...
   / trailor floor metal or wood? #19
jb
:D You know, I do have a guy who swears that he uses his 'used' motor oil to treat his wood trailer deck with good results. Anyone ever heard of this? I've never done it myself. The Olympic, or Thompsons I use is considerably thinner than motor oil.
   / trailor floor metal or wood? #20
I use my old oil to treat my manure spreader. Not only does it protect the wood but then I run the chains through it to keep them lubricated.
30045 (A53424)
30045 (A53424)
2016 Ford F-450 Ext. Cab 4x4 10FT Flatbed Truck (A51692)
2016 Ford F-450...
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
2008 INTERNATIONAL WORKSTAR 7400 SFA 6X4 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
