Trans/Hydraulic Oil vs. Gear Oil?
   / Trans/Hydraulic Oil vs. Gear Oil? #11
remember.. utf is not a straight hyd oil.. it's actually formulated to work in trannies, hyds, power steering, and final drives.. wet clutches.. wet brakes.. etc.
if you want to get off the beaton path.. at work we have tons of cat equipment that use 30w or 40w engine oil in the trannies... ( torque converter )
soundguy
and thus the name UTF or universal tractor fluid, its universal. I think 80W90 and higher fluids are being used less and less. While my Kubotas and can use 80W90 in the front axle, they came filled with UTF.
   / Trans/Hydraulic Oil vs. Gear Oil? #12
yep.. lotsa common sump systems using utf vs multi sump systems with gear oil in some and hyds in others..
we have a bros milling machine ( soil stabilizer ).. has big chain boxes on the side.. manual actually specs 50w engine oil in em :)
soundguy
   / Trans/Hydraulic Oil vs. Gear Oil? #14
The relatively slow moving gears of a tractor could probably be lubed with bear grease and last quite awhile.
   / Trans/Hydraulic Oil vs. Gear Oil? #15
I've got a mower that says you can use anything from 75w up to 140w or a pourable grease in the 00# range..
soundguy
   / Trans/Hydraulic Oil vs. Gear Oil? #16
Really, its quite standard today. Every Kubota I have ever purchased uses hydraulic fluid in the front axle and of course, the transmission/hydraulic pump for external hydraulics. Even my old IH 454D used hydraulic fluid exclusively. Don't all manual transmissions use a light weight oil instead of "gear oil". I think your mistaken.
My tractor uses 80W90 Gear Oil in both the transmission and the front axle. It has a separate reservoir for the hydraulics which uses AW32.
Chris
2013 John Deere 35D Mini Excavator (A52377)
2013 John Deere...
2018 CATERPILLAR 318FL EXCAVATOR (A51246)
2018 CATERPILLAR...
Icon Golf Cart (A51694)
Icon Golf Cart...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2017 GENIE S-60X MANLIFT (A51246)
2017 GENIE S-60X...
2018 DRAGON 130 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 130...
