Transmision vent tube?
   / Transmision vent tube? #11
Check your breathers, you may have been hit by a dirt dobber...
   / Transmision vent tube? #12
I found it.....look carefully at your filler cap. There is a small hole that is on the side of one of the 'wings". Then look at the bottom of the cap and you will see a small hole near one edge. I had to clean mine out with a needle and air....25 years of "gunk" and crud.....look carefully and you will find it.
This should answer the "pressure" problem...
Thanks. I looked on my cap but no hole is there so I drilled on with a 3/16 drill. Ran the tractor for four hours and no oil is venting out the shifter areas. This is where it was most noticible.
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
2007 JLG 600S TELESCOPIC MANLIFT (A52705)
2007 JLG 600S...
2007 FELLA SM350 3 PT DISC MOWER (A55301)
2007 FELLA SM350 3...
STORAGE FEES (A54313)
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
