Transmission Calibration 2007 John Deere 3120
   / Transmission Calibration 2007 John Deere 3120 #11
You probably had a throttle position sensor issue. I had a similar problem last year. I suspect what the dealer did was calibrate the sensor. The throttle position sensor calibration on a 3x20 series is a bit more complex than chickenman describes, but easy enough. I really suggest you buy the technical manual for your model. It cost a few bucks but is well worth the price.
what is the calibration procedure on your tractor?
   / Transmission Calibration 2007 John Deere 3120 #12
it adds wear and tear on mine because there is no differential in the drive line between front and rear wheels so any tire wear puts a strain on the drive line also tight turns put a strain on it
I understand not using the MFWD under certain circumstances, but in most instances (for the type of work I do) I believe I strain my tractor less by using MFWD than by not using it. Sorta like walking around on two feet rather than hopping around on one. It is just a lot easier on two feet.
I guess it depends on how you use the tractor. I use the loader and backhoe 90% of the time, brush cut and till the other 10%. The loader works way better in MFWD, so much so that I just never take it out unless I hit the paved road.
interesting comments re MFWD - 2 different uses so 2 different preferences in working. 95% of my hours are in rough/uneven paddocks either slashing or doing bucket work so i leave mine in MFWD & only disengage when on roadways. i find that in uneven terrain the 4 wd function gives a better ride as machine is pulling & pushing so to speak. Cocre i see urs is a 2006 model, what sort of hours have u done, likewise Chickenman, if its not an impolite question to u both? cheers OG
   / Transmission Calibration 2007 John Deere 3120 #14
got mine in 04 and use it quite a bit but the hour meter display is shot so i'm not sure
i use mfwd quite a bit but try to avoid sharp turns with it and engage it and disengage while moving slowly but when just going to a work site i disengage it
i have a horse farm so it gets used much
i have been thinking of getting a regular hour meter to put on
   / Transmission Calibration 2007 John Deere 3120 #15
460 hours. I bought it used two years ago with 185 on it.
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
UNUSED LANDHONOR TP2-13-08D HYD TREE PULLER (A54757)
UNUSED LANDHONOR...
UNUSED SBC90 SANDBLASTER (A54757)
UNUSED SBC90...
30006 (A53424)
30006 (A53424)
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
2016 HINO 195 16FT BOX TRUCK (A54607)
2016 HINO 195 16FT...
