transmission Fluid
   / transmission Fluid #1
HD328
I was working my TS1610 yesterday and after a 1 hr. or so my trans. seem to get sluggish . I check the oil level by removing the oil level plug and the fluid looked like milk ?About a pint of this fluid came out. I did capture this and put it in a glass container to see if it seperates.After 12 hrs, I see no signs of water . Could mositure still be a problem here ? Or is this mormal ? Also , Is there a way to drain the fluid , I see no drain plug ? Any help would be appreciated.
   / transmission Fluid #2
It sounds like water. There is a drain plug by the rear axle. Also clean the screen.
   / transmission Fluid #3
The top loader transmissions are known for taking on water if the boot on the shifter isn't in good shape.
1268 (A50490)
1268 (A50490)
2016 Ford Fusion S Sedan (A50324)
2016 Ford Fusion S...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
Bobcat 443 Skidloader (RUNS) (A50774)
Bobcat 443...
2019 John Deere XUV560E Utility Cart (A50322)
2019 John Deere...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
