Transmission/hydraulic fluid drain/refill.
   / Transmission/hydraulic fluid drain/refill.
Soundguy.
Thank you you're input advice. Certainly will check on that.
Wow you sure have got/had a pile of machines.
Super how cylinders bleed out the trapped air without bleeding oil.
Thanks again.
Another old timer but doing a whole lot o lernin 'bout tractors.
Dennis- whiterose.
Yes I do have one buickanddeere. But its is very sparse with info.
Just says to remove the two drain plugs under the transmission case, drain, clean filter and replenish.
whiterose.
   / Transmission/hydraulic fluid drain/refill. #13
Soundguy.
Thanks again.
Dennis- whiterose.
they bleed out air because it will return to the sump on the other side. ( da cylinders ), and in SA, during exhaust it can. Some cycls have external bleeders. I have old ford cyl's like that. larg SA cyls. Oil ( ideally ) should not be getting past the outter seal.
Well that makes great common sense. I just needed to think it through!. Many thanks Soundguy.
whiterose.
1264 (A50490)
1264 (A50490)
1993 Ford F-150 Pickup Truck (A52377)
1993 Ford F-150...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2008 Volkswagen Passat Sedan (A51694)
2008 Volkswagen...
LOT LOCATIONS (A53426)
