Transmission/Hydraulic fluid
   / Transmission/Hydraulic fluid #11
KevinMcD said:
I have some MF Permatran III Trans/Hyd oil. Does anyone know if this is ok for the Kioti Tranny?
Thanks,
Kevin
It is compatible with fluid brakes, fluid clutches, all types of seals and o-rings and also hydro transmissions. So, it should work fine with your Kioti. There are even a few Mahindra owners on here that are using Permatran.
   / Transmission/Hydraulic fluid #12
Universal Hydraulic Tractor fluid. Just about any brand.
I typically tell customers, "If it says it is compatible with K*bota UDT it's fine"
Has to be compatible with wet disc brakes.
Island: Dexron III Mercon may work but it isn't one listed anywhere, better stick with the actual tractor Hydro oil.
It's one of those things where alot of different stuff MAY work but.....
BTI
   / Transmission/Hydraulic fluid #13
The tractor hydraulic/transmission 5 gallon buckets I saw at Costco appeared to have a generic label on them. Does it say somewhere that Shell makes it? Maybe I saw different stuff than Island Tractor. The label did say it was good for a bunch of different tractors including Kubota UDT.
   / Transmission/Hydraulic fluid #14
My Costco doesn't have anything in 5 gallon buckets. Just the DextronIII/Mercon stuff by the case in quart bottles cheap.
   / Transmission/Hydraulic fluid #15
Well I baught a couple of 5 gallon buckets of the Costco UTF today. On the label it says it meets or exceeds the specs for a whole bunch of makes of tractors. One of the listings is Kubota UTF. What is the difference between Kubota UTF and Kubota UDT? And is Kubota UTF used in HSTs?
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2019 John Deere 6175M (A50120)
2019 John Deere...
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
2019 Isuzu NPR-HD 24ft. Box Truck (A50323)
2019 Isuzu NPR-HD...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2012 Ford F-150 (A50120)
2012 Ford F-150...
