Oil & Fuel transmission oil cooler hose leak
   / transmission oil cooler hose leak
I was getting by with new bent hoses, but one came loose, it came completely off, yesterday. I left it idling unattended and when I got back to it I lost about 6 gallons!
What is the conduit for?
Will the repair kit with the straight hoses still balloon up?
I guess I need to check them at least once a year and make sure they're tight and not deteriorating!
   / transmission oil cooler hose leak #12
can you still get bent hoses at new holland dealer?
   / transmission oil cooler hose leak #13
I got the repair kit three years ago and have not touched the straight hoses yet. My bent ones I had to replace one or the other each year. Money well spent in my ok.
   / transmission oil cooler hose leak #14
I picked up a few of the bent hoses at a dealer going out of business. I would like to switch over to the "kit" at some point though. I was also wondering what the conduit was for?????
   / transmission oil cooler hose leak #16
What the heck is a "bent hose"? I've never heard of that term before.
It is a hose with 90-degree bend in it.
You would think they could source a more robust hose, I'm on my 3rd pair and the current ones are starting to slightly bulge.
   / transmission oil cooler hose leak #17
Ahh! So simple! Yes, you're right about them using a more robust hose. Somebody cheaped out apparently.
   / transmission oil cooler hose leak #18
Conduit - I meant the 2 steel tubes that came with the upgrade kit. Sorry, my poor choice of words.
The straight hoses also deteriorate. Mine lasted 2 years and a couple hundred hours of tractor time before they split. New replacements from NH are about $6 each.
   / transmission oil cooler hose leak #19
Wow, this was an old post, I finally gave up about 4-years ago on replacing the hoses with the 90 degree bend when they started to swell. I purchased and installed the hard piping which eliminates hoses with bends with no issues since.
7021 (A50322)
7021 (A50322)
1999 Volvo VN Truck, VIN # 4VA7BBJF9XN770848 (A51572)
1999 Volvo VN...
2015 Honda Odyssey VAN (A51694)
2015 Honda Odyssey...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A53472)
2017 Yale GLC050VX...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
