Transmission type selection
/ Transmission type selection #41
Thank you all. I feel I have learned something from this thread.
I like to look at all the trouble threads to see what problems are out there and how people fix them. I find it quite interesting, and I try to learn from the experience of others and the vast knowledge posted here. Somehow by doing this I arrived at the misconceptions that I had on HST tractors.
/ Transmission type selection #42
Ok, I've read almost all of the replies to the OP's questions.
One question keep coming into my head.
Everybody agrees that if you're doing field work, plowing etc, that a geared transmission is best. But nobody has said WHY? Does and HST have problems with long straight heavy loads?
Wedge
There are no problems, just the benefits of HST are the ability to change direction and vary speed easily. When you don't change direction and operate at the same speed -- those benefits go away. Then it's down to the slight (~10%) drop in fuel efficiency.
I have 3 tractors (not counting lawn mower size machines). 1 crash box gear tractor, one power shift and the smallest and newest one is hst. I choose the hst for most loader operations even though the bucket is the smallest. It is more productive moving dirt -- that's all I care about when using the loader, productivity.
I also would like to cast doubt on the statement that hst's are non-reliable. That's not been my experience at all.
/ Transmission type selection #43
I thought of another reason to own a Hydro......I have a couple of grandsons that are soon able to drive and help me in my food plot and hunting land work. Kids dont learn about gears and clutches anymore.....and hydros are easy to learn on. Easy to learn and safe = big benefit IMO. :thumbsup:
/ Transmission type selection #44
Gordon,
Having read lots of your posts and considering what you do with your tractor you might want to try out a hydro tractor next time you consider a new machine. Most of my time in the seat has been on gear tractors and like most of the people who have operated them you can be proficient with gears. For the last six years or so I have used the ehydro Deere's and find them easier to work with especially in close quarters.. Still have a gear tractor that I am fond of too.
From what I have been able to discern about most peoples' uses of tractors on TBN a hydro tractor is well suited for them. My reasoning is based on the fact that they perform a wide variety of tasks with one machine in most cases. Very few members are involved in any serious farming with large acreage tillage needs where a large gear tractor would make more sense.
/ Transmission type selection #45
Wedge
HST results in some power loss and probably some less fuel economy. This means little to a guy tilling or plowing an acre or so, but those losses can be considerable when working a couple hundred acres.
Also, there's no advantage to HST in field work...the operator isn't shifting gears constantly. But the losses in efficiency can add up.
Heck, even when I had a collarshift transmission (non-synchro) and finish mowing an acre yard, I shifted from a forward gear to reverse only occasionally.
I think a lot of you HST guys think a gear guy is shifting frequently. That's not the case with most work, other then back and forth loader work (even then, the difference is in fractions of a second).
I've read these HST vs. gear threads for the last 10-11 years. They never get resolved...and this thread won't be the last.
Just buy the transmission you want. If you're an experienced operator, you won't need to ask which one to buy. If you're a person just getting into farming...well, I'd guess most (but not all) responders (including me) are non-agricultural operators and our opinions wouldn't really apply.
/ Transmission type selection #46
Roy,
I agree this issue of transmissions has been going back and forth for a long time without being resolved. Doubt it will be resolved anytime soon either.
Using a hydro is more than eliminating the use of the clutch or power reverser tranny to change directions though. The more important advantage is the control of movement such as when finish grading with a boxblade. Sometimes you only move a few inches and need to slow down or stop to adjust the box before proceeding with finish work and this is easier to accomplish with a hydro tranny.
I suspect if you used a newer ehydro tractor for a few weeks you would better appreciate the benefits. You may still prefer gears but atleast you would have a better comparison.
/ Transmission type selection #47
Roy,
Actually, in my case, there would be little benefit. One of the results of a stroke (about 12 years ago) is very little control over my right foot (I can push down, but I cannot lift my foot up (trying pivoting the toes up while setting with feet on the floor...the ball of your foot comes up too...that's what I can't do). I've adapted to this and, in my particular case, the hand throttle and low gear works best...for close work.
But that's just my particular situation...
/ Transmission type selection #48
Roy I can see how your situation would not work so good with a hydro, I have wondered if someone with arthritis in their right ankle would be able to work a hydro very well, maybe better with the 2 pedal setup instead of a treadle like mine. I have trouble with my left knee, and the less clutch work the better with it. Getting old is not for sissies.:D
James K0UA
/ Transmission type selection #49
as said there will always be debates over gear or HST tractors.an both have their place an uses.for me i wanted tobe able to drive a tractor when i wanted to or needed to,because it was pretty much impossable for me to use the clutch anymore.an it sure is a blessing tobe able to get on the tractor when i want to.
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2008 CHEVROLET C8500 DUMP TRUCK (A59823)
2008 CHEVROLET...
12ft 9in Altec Service Bed (A61165)
12ft 9in Altec...
Bell 1600 Gallon Nurse Trailer (A61307)
Bell 1600 Gallon...
159119 (A60430)
159119 (A60430)
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A61307)
2023 Kubota...
