Transplanting wild oak trees (small)
   / Transplanting wild oak trees (small) #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
In preparation for a future house, Im planning to plant approx 40 - 60 oak trees on both sides of my driveway. I have considered using nursery oaks and may end up doing this, but I would like to dig up and transplant small oaks that are already growing on my property. Im talking small trees that are knee / waist high, and have a diameter approx. the size of my thumb.
1) Any suggestions on technique (digging up and moving) are wanted
2) Are there any "specific" tools (spades and shovels) that would make the job easier of more successful (Im wanting specific brands, shapes, designs, etc.)
thanks
   / Transplanting wild oak trees (small) #2
Just make sure the digging equipment is sharp. :thumbsup:
   / Transplanting wild oak trees (small) #3
If you have the time to wait. Dig half around and wait a month or two before digging the other half. In the new hole put something that will hold water could be as simple as some shredded up newspaper or those gel things. Water every other day for a while then every third day and so on. works 80-90% of the time nothing is 100%
I have also when out and cut all the way around the tree with a spade and left it for a few weeks with luck. Get as much tap root as you can when you dig it up
   / Transplanting wild oak trees (small) #4
Have you checked with your state conservation department, assuming Texas has one? here in Missouri, I can get bare root trees of many varieties from the state nursery for very little money. There are lots of different oaks, and they are hard to tell apart as saplings, but the state nursery knows!
Chuck
   / Transplanting wild oak trees (small) #7
Texas Forest Service https://tfsapps.tamu.edu/wtn/StoreFront/index.aspx
has bare root seedlings for $35 for 24 - 5 or 6 types. I planted a bunch last spring. They did great till the rain left then not so much!
:thumbsup: I have used them 10-15 times, There was one in East Texas (Indian Mound) but it closed. Figure out what you want early and order since they go fast. The hardwoods I have received have been great growers (until this drought) and averaged 12-16" tall.
   / Transplanting wild oak trees (small) #8
If there are things that will gnaw at them tree tubes might be good, or a piece of 4'' perf pipe that you use around the base to keep the weedwacker off of them.
   / Transplanting wild oak trees (small) #9
thanks
I don't know what kind of oaks you guys have down there, but oak trees up here don't grow too fast. Trees that are 4 ft high here now might be 20 footers in 20 years. I have used the state nursery here a couple of times.
   / Transplanting wild oak trees (small) #10
I believe NE Texas has similar climate to here in NC- fairly mild winter, hot, humid summers with around 40" rainfall each year. I had a white oak that volunteered in a flower bed and since there were no trees already in that side yard I let it grow. My son was 2 when I found that tree, and I think the tree was about the same age (knee high). 25 years later the tree is 50' high and the crown is probably that wide with a beautiful globe shape. I was sure happy I didn't pull that sapling up.
PH
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A45336)
2019 Generac...
2008 HOLDEN INDUSTRIES, INC 100 ANTENNA TRAILER (A47001)
2008 HOLDEN...
2007 PARK MONORAIL (A47001)
2007 PARK MONORAIL...
3pt Ditcher (A47307)
Mack Model R Truck (A47369)
Mack Model R Truck...
CAPITOL 760-02-1160T WHEEL TRENCHER (A47001)
CAPITOL...
