Transporting barrels of water...
   / Transporting barrels of water... #21
I put open-top plastic drums in the loader and wrap quick tie-downs to keep them from sliding out, floating a 5 gal bucket upright in each to minimize sloshing/splashing, then drop 'em off if I have enough free to do so. I've put (plastic) window screens over the tops to let rain top them up and keep bugs/litter out when sitting. I lug smaller amounts in pairs of 5 gal buckets on the floor of the golf cart with 2 gal ice cream tubs floating & they usually 'jostle' out to the trees or fire pit more than 3/4 full, with a dipper in each one.
I fill drums from the pond (a foot-deep creek oughta do) with a 2" gas pump vs over-drawing my well & dip with the 2s to fill the 5s. Rear forks might lift more than a FEL depending on your tractor & equip. I suggest these as a temp solution while you sort out the tank possibilities. With more than two drums, weight alone might be a problem even without sloshing, & mobility might not be 'all that'.
This is going on a trailer with a 3500# axle that will be pulled behind the RTV500, the BX2660 or the B7500. Weight shouldn't be an issue, I was mainly worried about water sloshing around and pushing the tow vehicle in hard stop like the current 30 gallon barrel in a "lawnmower trailer" does.
Aaron Z
   / Transporting barrels of water... #23
This is going on a trailer with a 3500# axle ... Weight shouldn't be an issue ...
Considering load per tire I suggest using fairly wide 'LTs' vs typically narrow trailer rims/rubber if ground covered will ever be soft. (That's what I was getting at with o'all wt.) Mounting high may make them easier to tap, but mounting low will reduce tipping if one wheel hits a soft spot. If you're lucky, you'll never have to back up with a full load. ;)
I've been lucky that I never had to water more than 175 trees at a time, and rarely more than twice in one week. (Hot sand doesn't seem to hold water very well) :rolleyes:
Ah. I get it now.
It currently has some very tall, skinny and ancient (in tire years) trailer tires installed on its 13" rims. I have access to some wider 13" tires which (if they will hold the weight) will get installed the next time I make it out to where they are. If that doesn't work, I will hit the local junkyard for some 15" Ranger rims and get the shortest 15" takeoffs I can find put on them.
Aaron Z
   / Transporting barrels of water... #25
totes work great here, just leave to lid off or you tank will turn into a pancake when you open the valve.
2013 Infiniti G37 Coupe (A55853)
2013 Infiniti G37...
1989 AM General M998 HMMWV 4x4 Humvee Truck (A55852)
1989 AM General...
HOMEMADE HEAVY DUTY FIRE PIT RING, BLACK (A57192)
HOMEMADE HEAVY...
2014 Ford Transit Connect XLT Cargo Van (A55852)
2014 Ford Transit...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
UNUSED FUTURE FT13C EXCAVATOR (A57192)
UNUSED FUTURE...
