Travel Trailer Towing Experiences?
   / Travel Trailer Towing Experiences? #41
I have a dodge Ram 1500 with the 3.7 V6. Rented a 4000lb travel trailer in MI and towed it to Colorado and back. Got right on 10mpg and at the time gas was $5/gal Ouch ! It worked out to 50c/mile.... ~5000 mile round trip = $2500 for gas alone. NOT a cheap vacation.
The problem was, that when renting a trailer from one of the large outfits, you need to get in at least 1-2 weeks prior to departure with the reservation. I left it too late, or perhaps I should say that my vacation was granted "last minute".
You will save a ton of money and take a lot less time getting to your destination if you can rent closer to the destination. It will also save a lot of wear and tear on your vehicle.
Meanwhile I bought a fairly new HiLow trailer off ebay and while in the same weight range it is no higher than the pickup roof when lowered. I now get 14-16mpg when towing at speeds up to 70mph, so it is a huge improvement. My truck still sucks when going over the rockies and in some places like Mesa Verdi there are hills that need first gear. Its the engine and rear axle combo (3.5:1). 6 gears, but 4 of them are too high for hills...
   / Travel Trailer Towing Experiences? #42
Very good post. You proved all the points I was trying to make. The air drag is more lethal than the weight and the 3.42 and 3.55 gears are no match for any hill but do ok on level land.
I had posted about pulling a 10,000# boat with a 3.55 geared F-150. It did ok around Indiana which is flat, not good but tolerable. I got in Kentucky with real hill and some heat and the thing literally would not make it up on hill, probably a 20% or more grade, and I had to use 4Low to get the gearing in my favor for about 2 miles.
Chris
   / Travel Trailer Towing Experiences? #43
I should add that I about burnt out the clutch on mine trying to back the trailer into a site at Mesa Verdi. At about 8500ft the engine has no torque whatsoever and combined with the high rear axle ratio and reverse gear meant that the only way to stop it bogging down while backing up "uphill" was to slip the clutch. The cluch stank to high heaven by the time I got over the curb and up the rise into the site.
With a 4.7 or 4.8 rear axle ratio it would have been much better. Unfortunately, mine is straight 2wd so no low range which will obviously help greatly with this kind of problem. Won't help with the hills on I70 though. Its good asphalt and only AWD is acceptable. Run 4WD and you will likely wind up the drivetrain due to slight mismatching of the tires front to rear.
   / Travel Trailer Towing Experiences? #44
Chris
I'm feeling pretty good about my Chevy 1/2 ton. We are vacation. We live in South Central Ohio and just went down to Lake Cumberland. Left there this morning and now we are in Lexington at the Kentucky Horse Park. I'm pulling our new Jayco 32 BHDS travel trailer. It weighs 8,000 lbs empty. We planned on keeping it loaded pretty light, well once we decided to go for a week, that went out the window. It is now loaded heavy, except I have avoided hauling water. I've been able to keep it between 55 & 60 most of the way. A few spots I hit 65 and then some of the hills I had to drop down to 45 in second gear. There is one hill I have to drop to 35 MPH because of the length otherwise the temp starts to rise. This is a 99 ECSB 4x4 w/ 5.3 and 3.73 gears. I've checked the MPG twice on the fill ups. I'm getting right at 9.2 MPGs. I don't think too bad with 2 adults and 3 kids in the truck.
   / Travel Trailer Towing Experiences? #45
Yea, your truck with the 3.73 gears is in a whole other league as the OP with the 3.42 gears. As you stated it dropped down quite a few gears and to 45 mph, just think of how it would be with less gear. Driving 55-60 with a load or not will really improve your mpg. That is where the manufactures set up the vehicles and get the claimed mpg on the window sticker. With everyone driving 75-80 mpg really drop. The instance I talked about having to use 4 wheel low was at Lake Cumberland in 2004 at Alligator II dock. I bought a F-250 Diesel 3 days later.
I will be coming your way tomorrow. Heading to Tennessee to Lake Norris. Check it out if you have never been there. We used to go to Cumberland 3 times a year since 1986 but stopped going 3 years ago and will probably never go back since finding Norris.
Well, I ended up doing something that I didn't even list as an option in my original post. I ended up going out and buying a used 18' (or 22' depending on you you measure it) travel trailer. It doesn't make sense financially, and it is going to be harder to deal with pulling it up and back than it would be to just rent one there, but my dislike for renting things overcame my common sense.
I pulled it back from Austin today (left this morning at 5AM and got home at 6PM) and it did pretty good. Ended up getting 9.3 mpg which isn't as good as I had hoped but there is 2,750' of elevation gain from Austin to Lubbock (500' to 3,250') so I think that had something to do with it.
I left it in 3rd gear except a couple expirements in drive and kept it at 65mph for the most part (I let it get to 70 down the hills and dropped to 60 going up the hills). I had 2 hills that it ended up in 2nd gear on and if they had been much longer I would have had to slow down under 55 mph (3,500 rpms in 2nd gear). It peaked at 99 degrees on the drive home so it worked fairly hard.
750 miles on the clock today with 375 of those pulling the trailer home. It didn't have an equalizer hitch or sway control bar and it wasn't too windy so it wasn't bad, but I did go through a storm right at the end that confirmed that it will be on order Monday morning. Empty weight is 3,700 with just barely over 500lbs of hitch weight. That worked okay with an empty truck bed and no other passengers or cargo, but I'm sure I'll have some more weight in the truck on my trip to Wyoming so I'm getting a 501 - 800lb weight distributing hitch for it.
Here's the truck and trailer at the house this evening.
Lot's more pictures and a little more detail on my blog if you are interested - Nathan's Blog
   / Travel Trailer Towing Experiences? #47
Travel trailers are measured for overall length, although the actual overall length may vary a foot or so from what the manufacturer calls it; e.g., my first one was called a "24RB" (rear bath) but actually measured 25' 3" overall. Even when a truck can easily handle the tongue weight, dips or humps in a road can cause a lot of bounce that a load distributing hitch will prevent, and you definitely want a sway control. I've talked to many, many RVers who wrecked their first travel trailer and said the dealer didn't tell them about sway controls, only the load distributing hitch.
Incidentally, having driven from Dallas, through Wichita Falls, Amarillo, Raton, NM, to Denver a few times, I sure understand about the elevation change. Your truck seems to be working harder (and it is) when the road appears to be level.
   / Travel Trailer Towing Experiences? #48
You made a wise move by not towing a 7,000+ travel trailer with your setup to your destination. My dad bought my 01 Silverado Z71 with 3.73 gears last year. He bought it because he sold his 3/4 pickup. This spring my mother purchased a Jayco EXP travel trailer that is approximately 7,000lbs to take to Florida to visit family in the winter. Of course the dealer informed her that my old 1/2 ton could tow it. They took the trailer 100 miles south down I-81 in VA (appalachian mountains)for the first outing. This section of interstate has a lot of elevation changes for our area and the pickup constantly changed gears between 2nd and 3rd to maintain 50-60mph. There were times when the engine stayed between 3k-4k rpm for several minutes to keep the truck from going under 45 mph. The truck got 7mpg on two trips with the camper and the camper was straining the truck.
My dad ended up getting a 2500 Duramax since they have planned to take the travel trailer to Florida this winter. I'm not advocating a new truck but the new truck made a huge difference and gas mileage is now running between 10-12mpg depending on the wind.
I've been trying to talk the wife into getting a 4wd Tahoe instead of her truck and letting me get a 3/4 ton pickup for a couple years now. She is sticking with her pickup and my company car is a Trailblazer so I can't convince myself that I really need the 3/4 ton pickup in addition to her 1/2 ton pickup. I would like a 5 or 6 year old plain jane 3/4 ton truck to haul my tractor back and forth to the land. Then I could buy a bigger trailer and then I could buy a bigger tractor!!! I'm afraid it would end up being a pretty expensive pickup by the time it was all said and done! :D
   / Travel Trailer Towing Experiences? #50
That sounds like what happened to me. I started out with a TC 30 that my 1/2 ton was able to tow well. Then I traded the TC 30 for a TC 40, which didn't agree with my 1/2 ton Silverado. I then bought a heavier trailer and then just last fall a Dodge 2500 CTD. It never ends. Deer hunting is now costing me about $500 per pound!
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
Manac Walking Floor Trailer (A50322)
Manac Walking...
Toro Mower (A50324)
Toro Mower (A50324)
2016 Kenworth T270 Truck, VIN # 2NKHHM6X1GM110171 (A51572)
2016 Kenworth T270...
2006 BOBCAT S130 SKID STEER (A52576)
2006 BOBCAT S130...
1990 JOHN DEERE 544E WHEEL LOADER (A52472)
1990 JOHN DEERE...
