Tread width specs for tractors
   / Tread width specs for tractors #1
piller
Oakdale, TN
Kubota M8540HD ROPS
I was looking at the M40 series specs and noticed the tread width specs for the different models. Is the tread width determined by the tires and wheels or are there differences in the front and rear axles?
   / Tread width specs for tractors #2
The thread width is the center to center measurment between the tires. It is not usually determined by the tires and wheels.
In the rear the adjustment is made by mounting the rim to the center disk in different configurations, reversing the disk and/or rim, etc. On 4WD models the front is adjusted the same way, but there are not as many combinations available. There may be a 4WD extension kit available for the front of the M40's to obtain wider settings.
The 2WD front axle is more adjustable, probably the axles slide within a tube.
Any other differences you see among the M40 models are probably due to different axle housing dimensions in the various model sizes.
Crown PE4000-60 Riding Jack (A49251)
Crown PE4000-60...
2014 Bomag BW145D-40 Vibratory Soil Compactor (A46683)
2014 Bomag...
2008 BMW 528i Sedan (A46684)
2008 BMW 528i...
International 1086 2WD Tractor (A49251)
International 1086...
2018 Chevrolet Silverado Crew Cab Pickup Truck (A48081)
2018 Chevrolet...
2012 Dodge Charger Sedan (A46684)
2012 Dodge Charger...
