Tree Shear, fixed blade
/ Tree Shear, fixed blade #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
New and interesting tree shear. Uses the force of the machine to push a "V"type blade through the tree. No moving parts. Will cut on the go.
YouTube - vcutter video# 1
YouTube - vcutter2
The system finally let me post this.
/ Tree Shear, fixed blade #2
Wow JJ! Never seen anything like that. So simple. One thing...it looks like you would need to go slow with a CUT and not ram...so as not to mess up your loader arms/cylinders.
/ Tree Shear, fixed blade #3
Watch out for falling limbs and tree tops. That shear of that design looks like a machine or man destroyer. Must have full enclosed and guarded rops for operator and full guarding for tractor/skid-steer using something like that. Speed wouldn't matter with a limb impaled in hood of tractor or operators head:eek:
I don't think it was designed for big stuff, probably no more than 4 to 5 in green tree. Should be fairly easy to build one.
/ Tree Shear, fixed blade #5
The beginning of the video looks like the machine takes some pretty serious ramming hits to get those trees down. And I wouldn't even consider trying this out without a full FOPS cage. My ROPS wouldn't be near enough protection to even consider it.
Also, what about hitting a 4" tree with *almsost* enough force to sheer it off? Could you get the blades stuck and not have enough traction to back out of it?
/ Tree Shear, fixed blade #7
Wow JJ
That is one of the most dangerous attachments I have seen in a long time.:eek:
Sure does cut through those big DEAD trees fast though.;)
Not sure how it would fair out with a large green tree though.
Thanks for the link, it was amusing.
/ Tree Shear, fixed blade #9
I like the grab and pull back feature for waters edge! ... Otherwise its all medium to HD bushog work, For my money Id take the versatility of the bushog to do this and other clearing functions well. ... A grabbing shear for waters edge tho is an excellent idea seed. Ill put it on my project list.
larry
/ Tree Shear, fixed blade #10
Yeah, most of the stuff they were taking down in the video could be done with a bush hog or flail mower. I'd be a little concerned about ramming into larger trees with the FEL on a CUT for fear of damaging the FEL arms. Skid Steers and bulldozer arms are tougher than those on our CUTs. This thing depends on momentum and mass to cut which requires ramming and that is not what tractor FELs are designed to do.
/ Tree Shear, fixed blade #13
You guy saw this version of the turbo saw, right?
Tree Removal - Skid Steer Tree Saw - Turbo Saw Tree Cutter
For you normal tractor owners...
Yes, I saw the video. I am still leery of using that type of cutter. My skid steer is standard flow at 21 gpm. That saw in the demo must be hi-flow which would help. On their website, they have models from 10-41 gpm. I can't imagine how the 10 gpm would even work-maybe for cutting grass.:D The biggest problem I felt was the binding of the tree on the blade with bigger diameter trees. I believe it is best to cut on just one side of the rotary saw. Yes, it worked much better if the tree was cut so it was falling away from the blade. However, often it takes too much time to reposition the skid steer and sometimes it can only be cut on one side. The wind also tends to push the trees as cutting and pinch the blade. I had binding so bad on the blade, that I almost could not pull the blade free and I have a large frame skid steer. I have chain saws bind in cuts but this seemed much more severe. Their blade is 26" diameter and the bobcat one I used was 24" diameter. Of that 26", much of the center is occupied by the yellow metal cylinder. The actual usuable cutting width of the blade is probably closer to 8". Larger trees will require a second cut on the other side to completely cut the larger trees. Also, I want to cut at ground level, no residual stumps. A tree 6-7" diameter 8-12" up from the ground may be 10-12" at or just below ground surface.
Maintenance must be much higher with replacement/sharpening of the rotary teeth. If they are carbide, probably can't easily sharpen them. Small angle grinder is all I need for my shears. Hit a rock with a rotary cutter and start replacing teeth. The booms of the rotary cutter is also a weak link for lifting or side forces. Also much more stress on the loader/skid boom.
With my dymax, I can half cut and lift down trees to move them out of the way. With rotary cut, the tree lays where it falls and blocks the next tree from being cut. I can also use my dymax like a dozer (has a HD brush guard) and push a tree out of the way. Not easy or recommended with the boom of the rotary cut.
If you see all the variations of tree shears available and in use, very few are rotary blade unless you have a specialized machine with either direct drive or lots of hydraulic flow. Bobcat call theirs a "brush saw". They are smart enough to not call it a tree shear or cutter.
/ Tree Shear, fixed blade #14
So what if you could put your stump grinder on its side? Probably would just vibrate a small tree... Not sure it would actually cut on a big tree.
I only ask cause i saw a Dingo Stump Grinder on its side... Not sure what the purpose was but assumed the guy was trying to knock down trees with it...
/ Tree Shear, fixed blade #15
Nice looking tool for trimming overhead tree branches. How much does it cost? It doesn't look like it would be so good for just driving along a fence however and doesn't seem to do the same job as the Samuri as it cannot be rotated to cut horizontally under a fence (though the Samuri cannot reach up to trim high branches either).
/ Tree Shear, fixed blade #17
This comment of mine was in regards to a post from a manufacturer of a hydraulic chain saw. TBN moderators have removed the manufacturer's post so just be aware that these comments do not relate to any of the devices still being discussed in this thread.
/ Tree Shear, fixed blade #20
Looks like disc blades would work well...
2021 John Deere Gator TX4x2 Turf Utility Cart (A64194)
2021 John Deere...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
Standing Horse Statue (A65583)
Standing Horse...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
2022 ALLIANCE NORTH AMERICA SDG45 GENEEATOR (A65643)
2022 ALLIANCE...
