Trencher vs Backhoe
   / Trencher vs Backhoe #1
stumpfield
Sierra Foothills
2005 MT265B
Which machine is more effective to dig and bury 1600' of 2" pvc water line 18" deep? My soil is very soft and easy to dig. My grading contractor said he can do it faster with his backhoe and a 12" bucket. However, he doesn't want to give me a fixed price bid or a ballpark figure. His rate is $90 per hour. I hate to give someone a signed blank check. I thought digging a 12" trench of a 2" pipe seem overkill. Should I look for someone with a trencher? How hard is it to operate a trencher for someone who never used a trencher before? Thanks for your comment.
   / Trencher vs Backhoe #2
STUMPFIELD
Do you have to go below frost line" most trenchers I've used wewe in the 3 foot and shallower range.
If your soil is soft I would try the trencher less disturbance on surface too
I would look double check on the pvc pipe issue if it will freeze it will break poly (black plastic) pipe might frese but it dosent break.
tommu56
   / Trencher vs Backhoe #3
The trencher. However, get the size bigger than they recomend. The extra grunt is worth it. If you can drive a tractor you'll have no problem operating a trencher. My opinion.
My dad loves to sit on his backhoe and will take any excuse - besides in his view it's a sunk cost. However, those oversize trenches take a lot longer to fill and settle, especially if you have a lot of clay in your soil. Ours act like swimming pools and become fluid after every rain.
   / Trencher vs Backhoe #4
From what you describe, the trencher will be much faster. Even a good guy on a backhoe needs to stop and move the machine every 6-10 ft. In good soil (no big boulders) and 18" deep a trencher will go like crazy.
Rent one. Not hard to use if you are comfortable operating machinery.
paul
   / Trencher vs Backhoe #5
If soil conditions permit, a trencher will always be faster than any hoe. Plus it give you fine backfill material and less disturbance to the ground.
   / Trencher vs Backhoe #6
I'll echo what everyone else is saying, that is the perfect job for a trencher. 2 guys could tear through that work in no time. One guy to dig the trench and the other guy glueing the pvc together and dropping it in the trench. Backfilling the trench is a breeze if your trencher has an adjustable blade. A little trickier if it doesn't, but still entirely managable.
   / Trencher vs Backhoe #7
The trencher is the way togo i put in 900 feet of 2 inch pvc pipe last year. I rented the trencher for 95.00 for a day. It took me 3 hours to trench it and i hit
a few tree roots. They are really easy to use and as said above wont tear your place up like a backhoe will.
   / Trencher vs Backhoe #8
trencher should be way quicker. as mentioned the back hoe has to be moved many many times during that 1600' trek.
steve
   / Trencher vs Backhoe #9
I had a professional dig some water line trench three feet deep for some three inch line. He was using my backhoe, a JD 510D which has plenty of power, a hundred plus feet per hour is all he could do, in your case a trencher would be much quicker. When they dug my power line, it was much faster with the trencher.
   / Trencher vs Backhoe #10
Don't forget....there are 2 kinds of common trencher: walk-behind
and ride-on. I have used neither but those I know who have used
both will never go back to the walk-behind kind. Even Home Depot
rents those.
One line, 18" deep, use a ride-on trencher.
   / Trencher vs Backhoe #11
Trencher. Much faster, much easier, and maybe most importantly, much cheaper. I rented a walk behind last year for $125 overnight, and it was the biggest model.
If you can ask if you can run one, you can run one. They are pretty easy to use. I agree w/ dfk, get a rider for that distance.
   / Trencher vs Backhoe #12
I agree with the trencher crowd. Even though it's a shallow trench and a backhoe operator can dig it really fast, he's also moving allot of dirt. Even if he had a 12 inch bucket, but more then likely, he'll have a 24 inch one. All that dirt has to be moved back into the trench, and this is where the trencher will far outperform the backhoe. Digging the hole is just half the job.
Eddie
   / Trencher vs Backhoe #13
The trencher is a good choice but you want to make sure you soil conditions are good. I rented a ride on one before which was very easy to use and very fast in good firm soil however I had to go across a very small stream bed and it just got stuck there. We had to have an excavator come in to finish digging that section. The second time I rented a large trencher attachment that fit on my skid steer. Again it did great when the soil conditions were good but eventually I had to give up using it because I have too many large rocks in my ground. Both of these trenchers would go through tree roots with little problem.
Eric
   / Trencher vs Backhoe #14
I rented a ride-on trencher to lay electrical wire to my sheds, once you get the hang of using it they do a good job and are fast. Didn't tear the lawn up much but does take some digging if you want to go deep.
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
2003 Big Tex 10PI...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
Crown Stand-On Electric Forklift (A59228)
Crown Stand-On...
