Trenching for burying electrical cable
   / Trenching for burying electrical cable #11
rlee6, I'm burying a 3/4" plastic black pipe with an electric fence charger wire in it to a depth of about 1.5 ft using a "subsoiler." PM me for details if you wish.... This is in hard clay with some rocks and a 50hp tractor.
It is possible that you could go 2.5' in pure sand with sufficient tractor power, particularly since it is vegitation and rock free. Alternatively, do you really need to bury it that deeply?
Local code says either 1.5' in conduit or 2' direct burial. Since the distance is about 100', I would rather bury directly than pulling wires through.
I have a 35hp tractor but no middle buster. Do you think it will dig 2' in sand without problem? Thanks.
It will cost about $200 for trencher rental. Since a middle buster costs less than that, if I can manage digging 2', I will buy the tool than spending the money on rental.
   / Trenching for burying electrical cable #13
Hmm... well, horsepower is a little light. I actually use a chisel point, not a middlebuster... am just trying to get something as narrow as possible, yet strong, down while carrying a chain that I can attach the pipe to. Physical pull from pipe is negligable, I was very surprised. I guess 98% of the effort is in pulling the chisel point forward. If it is sand all the way, you can make several passes to loosen up the sand before attaching the pipe. Staying in the track is a little difficult if it is not a straight line pull. If you know somebody who has a chisel plow you can take all but one of the shanks/points off and be ready to go to work. The point is, you are only trying to get the pipe down to depth desired... not dig a trench (think inside the trench)... so you just need something that penetrates to depth and that you can tie the pipe on to.
My guess is that you will spend maybe $250 to purchase the tool... things always seem to take a little more than one expects. But then you would have the tool and I've found it to be real handy.
I tried a trick that worked AMAZINGLY well. The idea is to get a nylong (strong) string from one end to another of a plastic pipe. Then, to pull the wire thru using the fish string.
In my case it was either a 2 or 2.5 inch PVC schedule 40 pipe. A friend said to just get a shop vac and blow the string thru. Well, I now know that would likely have worked... but being hard headed I took a small plastic pill bottle that was a little smaller than the ID of the pipe, drilled a hole in the end, put the end of the string thru it and knotted the string on the bottom. Thus the open end of the bottle faced away from the direction of travel down the pipe and the string goes into the open end.
I inserted the bottle into the pipe, pushed it in with my finger, grabbed the ball of string, turned on the shop vac and pressed the blowing end on the pipe. WOW... It felt like I had a monster in my hand... the string tugged and tugged wanting to run down the pipe... almost burned my fingers... blew out the other end in just a couple of seconds... length was about 70 feet.
I recently have enhanced the technique by inserting grease into the pipe just before inserting the wire to be pulled.... makes the pull much easier... but messier /forums/images/graemlins/wink.gif
   / Trenching for burying electrical cable #14
Last May I rented a Ditch Witch 1330 walk-in-front trencher from Home Depot to dig trenches for electric conduit, water lines and gas pipe. Total length was about 1100 feet and took about 8 hours. The electrical conduit and gas pipe trenches were 24" deep. The water lines went in 18" deep trenches.
The main electrical trench from my service pole to the outside load panel was 330 feet and took about 45 minutes to dig.
The 1330 is a 1000-lb machine that is hard to maneuver since it doesn't have a true skid steer capability. Be prepared to muscle it into position at the start of a trench to get it lined up. That was the hardest part in using that particular trencher.
   / Trenching for burying electrical cable #15
i have a d/w 1030 ad it will do 30 inches. im in sandy dg-ish and did 30 inches about 100 feet in around 20- 30 min also at the old house i did 50 feet in cobble root dirt in about an hour, jon
2018 JOHN DEERE 410L BACKHOE (A52706)
2018 JOHN DEERE...
Galvanized steel fence (A53424)
Galvanized steel...
2019 Kia Soul SUV (A55758)
2019 Kia Soul SUV...
Paint Sprayer (A47477)
New/Unused Pallet of Webbing Slings (A54865)
New/Unused Pallet...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
