Tricks for cleaning old fuel tanks?
   / Tricks for cleaning old fuel tanks? #11
That one is a good solution Piloon.:thumbsup:
   / Tricks for cleaning old fuel tanks? #12
I used a couple of things when I cleaned my old IH 340 utility gas tank years ago - I had the best results from using some Naval Jelly + some good sharp-edged gravel from the driveway and rinsed very well and dried before using a gas tank sealer. This quart of sealer was around $35 but it will do about 3 or 4 automotive sized gas tanks, can't remember the name of it to save my life. You pour some in the tank and of course turn it all around to coat the inside everywhere then pour the remainder back in the can. It forms a tough, very thin membrane and seals any leaks you might have. I did that tank about 13 years ago and the current owner says it's still holding well. I bought the can of sealer at my NAPA dealer back then.
Fuel Tank sloshing compound is something I have used a lot over the years... everything from antique car fuel tanks, motorcycles and power equipment.
I have one that I did in the 80's that is giving me problems... seems California reformulated gas dissolves the compound into a goo... what a mess.
   / Tricks for cleaning old fuel tanks? #13
Some motorcycle shops sell tank repair kits with polyurethane for stopping/ preventing leaks after the tank is cleaned. I second the loose bolts/ nuts and the muratic acid. If you're going to use the acid, you may want to dilute it. remember to add the acid to the water, not water to acid and use in very well ventilated area.:thumbsup:
Jim
x 2......IIRC, the stuff is called "Kreem" and it comes with phosphoric acid, MEK, and the polyurethane coating stuff......
It works real good after the nuts/bolts or rocks, then solvent/ cleaner
   / Tricks for cleaning old fuel tanks? #14
I used white vinagar to remove the rust then rinsed the tank with warm water and baking soda.
   / Tricks for cleaning old fuel tanks? #15
Just a quick word of caution if you are going to unsolder a gas tank...make sure it has not had gas in it for a long time! Flush it out. Force ventilate with compressed air or CO2.
I use CO2 from my mig welder if there is ANY odor from tank before/during grinding or applying heat. CO2 displaces the air and will not support compustion.
2020 KUBOTA RTV...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
2002 International 4300 Cab and Chassis Truck, VIN # 1HTMMAAP02H548742 (A51572)
2002 International...
JACTO ARBUS-1000 LOT NUMBER 71 (A53084)
JACTO ARBUS-1000...
