TRIVA FUN
/ TRIVA FUN
F-82
In October 1943, the North American Aircraft design team began work on a fighter design that could travel over 2,000 mi (3,200 km) without refueling. It consisted of a twin-fuselage design, somewhat similar to the experimental German Messerschmitt Bf 109Z "Zwilling". Although based on the lightweight experimental XP-51F, which would later become the P-51H Mustang, it was actually an entirely new design. North American Design Chief Edgar Schmued incorporated two P-51H Mustang fuselages lengthened by the addition of a 57 in (145 cm) fuselage plug located behind the cockpit where additional fuel tanks and equipment could be installed. These were mounted to a newly designed center wing section containing the same six .50 inches (12.7 mm) M2 Browning machine guns as a single-engine Mustang, but with more concentrated fire. The outer wings were strengthened to allow the addition of hard points for carrying additional fuel or 1,000 pounds (500 kg) of ordnance. The two vertical tails were also from the XP-51F, but incorporated large dorsal fillets for added stability in case of an engine failure. The aircraft had a conventional landing gear with both wheels retracting into bays under each fuselage center section.
Record-setting
P-82B-NA 44-65168 "Betty Jo" taking off from Hickam Field, Hawaii, 27 February 1947.
On 27 February 1947, P-82B 44-65168, named Betty Jo and flown by******name of pilot???*******, made history when it flew nonstop from Hawaii to New York without refueling, a distance of 5,051 mi (8,129 km) in 14 hr 32 min. It averaged 347.5 miles per hour (559.2 km/h). This flight tested the P-82's range. The aircraft carried a full internal fuel tank of 576 US gallons (2,180 l; 480 imp gal), augmented by four 310 US gal (1,173 l; 258 imp gal) tanks for a total of 1,816 US gal (6,874 l; 1,512 imp gal). Also, Colonel Thacker forgot to drop three of his external tanks when their fuel was expended, landing with them in New York.[3]
To this day, it remains the longest nonstop flight ever made by a propeller-driven fighter, and the fastest such a distance has ever been covered in a piston-engined aircraft (the record for the longest unrefueled flight by a propeller-driven aircraft of any type is held by the Rutan Voyager). The aircraft chosen was an earlier "B" model powered by Rolls-Royce Merlin engines
/ TRIVA FUN #792
That was me and no it was not wrong:
Crash Almost Killed Apollo 11 Astronaut ...
Video for flying bedstead crash▶ 0:37
www.youtube.com/watch?v=xJa4yQ0AIbU
"Dec 6, 2013 - Uploaded by Roy Dawson
Despite the incident, Armstrong praised the craft humorously dubbed the "flying bedstead," saying it did ..."
Googling "flying bedstead" will lead you as the first hit "niel Armstrong almost killed by crash..."
2nd hit is the British one. No, I didn't google it before I answered the first time.
Harry K
Yes, it was you and yes, you were wrong. The original flying bedstead was the British Rolls Royce Thrust Measuring Rig (TMR) which predated the LLRV (the one Neil Armstrong crashed) by 10 years. Some people also called the LLRV a flying bedstead as well, not knowing the origin of the nickname.
/ TRIVA FUN #793
The U.S. made Bell P-39 Aircobra was exported to the USSR in great numbers because the USAAF didn't want it. It's engine was located behind the pilot and drive the prop with a shaft between the pilot's legs. It was also unusual because it had a 37mm cannon firing thru the prop hub. The Soviets usually changed the cannon to a 20mm or 23mm, don't remember which, just remember reading that they did. The P-39 didn't have a supercharger and was useless above 15,000 feet which is why it wasn't wanted by the U.S. or Brits. Most combat in Russia was at low altitude were the Aircobra excelled. Also the 37mm cannon was very low velocity and not good for air to air fights.
Well said. I recall that Chuck Yeager, in his book, said that he really liked the Aircobra, which was used as a trainer, at least for a time. I believe it was fitted with a GM Allison engine, the same as the P-38 and the early P-51's, but sans supercharger. I also read that it got pretty exciting if the drive shaft, which ran between the pilot's legs, ever broke.
/ TRIVA FUN #795
Nothing was said about it having to be the FIRST one. Not just some people called it that. It was the common name in the news back then.
Harry K
/ TRIVA FUN #796
forgot to drop three of his external tanks when their fuel was expended, landing with them in New York.[3] To this day, it remains the longest nonstop flight ever made by a propeller-driven fighter, and the fastest such a distance has ever been covered in a piston-engined aircraft (the record for the longest unrefueled flight by a propeller-driven aircraft of any type is held by the Rutan Voyager). The aircraft chosen was an earlier "B" model powered by Rolls-Royce Merlin engines
Uhh. I will guess Col Thacker :)
/ TRIVA FUN #798
Cowboys of the old west wear spurs. What was the name of the bell like accessories worn on the raul of the spur? What was there purpose?
They're name is a Jinglebob. They're worn to cause a slight jingle. Supposed to be a soothing sound of communication with the horse.
/ TRIVA FUN
Save for the 30/30 cartridge. What cartridge has killed more white tail deer than any other????
2016 FREIGHTLINER CASCADIA 125 6X4  T/A  SLEEPER TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
2018 Ford Escape 4WD SUV (A59231)
2018 Ford Escape...
Giyi GY-QSJ Mini QA Broom Sweeper (A60463)
Giyi GY-QSJ Mini...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
