Trottle cable
/ Trottle cable #1
BeeFarmer
S.E. Ohio
TC 33D
I was doing a annual pm of my 33 and was just curious to check the throttle linkage\cable. I pushed the throttle to full open and then check the throttle linkage\cable at the end of the link and found that I could turn the linkage another 1/8 inch or so. Therefore I could get more out of the unit if I wanted to adjust the linkage. Now.. I am not sure of the verbage here but let me try it another way. I decided not to adjust the cable\linkage as this is my way of controlling myself from running the unit up full throttle but... my question is... What should be the out of the factory RPM be at full throttle?
/ Trottle cable #2
<font color="blue"> What should be the out of the factory RPM be at full throttle? </font>
out? /forums/images/graemlins/confused.gif
/ Trottle cable #3
You should have a governor on your engine to control the wide open throttle RPM. My guess is it's somewhere around 3000 RPM. Adjusting the throttle cable or linkage should not have any effect on the RPM at which the governor kicks in.
/ Trottle cable #4
Right, but if you could get it more throttle, wouldn't that help it in high load situations, where you aren't on the govenor?
/ Trottle cable #5
I can't tell you what high idle is on your 33, but the op manual will. High idle is set at the throttle shaft on the injection pump and is seldom if ever off by much. If I were you, I would adjust the cable to achieve the high idle spec and use it whenever necessary.
/ Trottle cable #6
<font color="blue"> the high idle spec </font>
High idle for the 33D is 3,040.
/ Trottle cable #7
A bit off topic, but didn't I hear that the the Class III have no governor ???
Don't remember who said it though /forums/images/graemlins/confused.gif
/ Trottle cable #8
Wrong. Very very few offroad engines are without governors. In fact, I can't think of anything bigger than a weed eater or chainsaw without a speed governor of some type.
/ Trottle cable #9
</font><font color="blue" class="small">( didn't I hear that the the Class III have no governor ??? )</font>
At some point, someone said that the class IIIs didn't have a governor (DieselPwr maybe?). That's not the case. As RickB said, there is a governor, and it's driven by weights similar to flyweights. The weights allow a cone to change position and move an actuator shaft that connects to the injector pump. That's the simple description. /forums/images/graemlins/crazy.gif
The governed speed for our engines is 2815 to 2855 RPM no matter if you have a TC35 or a TC45.
...now I sure hope I didn't "lie" too much. /forums/images/graemlins/laugh.gif This is all in the Repair Manual and I'm paraphrasing heavily. /forums/images/graemlins/blush.gif
/ Trottle cable #10
</font><font color="blue" class="small">( wouldn't that help it in high load situations )</font>
I think the rpm range and the torque curve would have to be analyzed to say for sure. If the maximum torque is at 2500 RPM, wouldn't you want that RPM to be achieved under all load conditions? If your throttle is above that RPM, then the injector pump should control the flow rather than throttle position.
Sounds good, right? Well, it's just a SWAG from what I read about governor operation. /forums/images/graemlins/blush.gif You may well be correct in your assertion. I'll have to defer your question to a real expert. Any takers? /forums/images/graemlins/wink.gif
/ Trottle cable
Oops.. ok what should be the rpm speed at full throttle. /forums/images/graemlins/blush.gif
/ Trottle cable
I've heard that you can crank up the diesal to a unit. What exactly is that all about and is it safe to do it?
/ Trottle cable #13
Jinman, that sounds good to me... I was thinking of those times when I needed to add throttle when running the blower to keep the revs up.. I found that even with very heavy snow my 33 had more than enough power to cut through it.
/ Trottle cable #14
</font><font color="blue" class="small">( you can crank up the diesal )</font>
That's an activity best left to experts in my opinion. It's certainly not for an amateur like me. I'd think you would certainly void any warranty you had left and take the chance of overstressing or over-revving your engine. If I need more power in a tractor, I'll buy a bigger tractor.
But that's just my answer and what makes me feel comfortable. That doesn't mean it can't be safely done by an expert. /forums/images/graemlins/cool.gif
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
