Trouble starting JD 4210 4wd
   / Trouble starting JD 4210 4wd #1
PaulH
I own a JD 4210 4wd w/HST. It has about 1800 hrs on it, and I got it used (came with the farm) about 2 yrs ago, but it's in very good shape -- has seen only light use and is stored in a garage. I use it for light utility work around my place -- front loader, a rear snow blade for the clearing the driveway, plus I do a bit of moving a hay wagon around. One thing I could always say was, this one always started right up w/no trouble, even in very cold weather (I live in Wisconsin).
Yesterday for the first time, it wouldn't start. It turned over 3 or 4 times, but a little more sluggish than normal, but I didn't think much about it at first, because it was cold (12 degrees). Then suddenly it cut out and started going "rat-a-tat-a-tat" real fast, almost like a real loud industrial sewing machine sounds. I immediately let go the key. I repreated this 3 or 4 times, and it got progressively worse (fewer cranks before it cuts out). The last time, it cut out almost right away.
The battery is fine -- I checked fluid levels, cleaned off the terminals and clamps, and checked the charge. Also, the headlights are nice and bright when I turn them on.
I'm wondering, is my starter broken? I'm reluctant to call my JD dealer because every time I do, it seems like it costs me big-time.
Thanks for your help.
   / Trouble starting JD 4210 4wd #2
i would try replacing the battery. it could be getting weak! i would try and get one with more cold cranking amps. and also check the alt, to make sure its charging. good luck !
   / Trouble starting JD 4210 4wd #3
If I'm understanding you noise description right. Does it sound like a fast clicking sound? If so, most likely, you either have a weak battery or a bad battery cable connection somewhere.
   / Trouble starting JD 4210 4wd #4
Clean all wire connections going to the starter solnoid and
all connections on the battery. There should be a small wire and 2 heavy cables on the solnoid. Problems like this are sometimes caused by not enough electrical power to hold the
heavy contacts in; so they start to dance and that is the
rat-tat-tat you hear. Seen problems like this before and solved it this way. Be sure solonid is grounded good also
Good Luck
   / Trouble starting JD 4210 4wd #5
I had the same problem with my 4210. I cleaned/checked the terminals and connections and charged the battery to no avail. A new battery solved the problem even though the old one checked okay.
   / Trouble starting JD 4210 4wd #6
If you don't replunish the water in the battery, they won't last more than 2 years. Clean terminals very very good. If that doesn't do it, get a new battery if you havn't been taking care of the one you have.
   / Trouble starting JD 4210 4wd #7
If changing the battery doesn't help, try checking all the fuses.
I have a 4200 which was cranking but not starting. The problem was fixed when I checked the fuses and found several that had shaken loose. Same kind of scenario, backed the tractor into the shop, running perfectly, then later it wouldn't start,
. I tried all the usual things, nothing worked until I pushed in all the fuses. No problems since. Might be worth a try since it's such a simple thing to do.
lekwyo
JOHNSON 5 1/2HP SEAHORSE OUTBOARD MOTOR (A58374)
JOHNSON 5 1/2HP...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
2014 Aerway Aerator (A55973)
2014 Aerway...
gravely riding mower (A55758)
gravely riding...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58017)
2015 FREIGHTLINER...
Mini-Excavator Heavy Duty Weed, Brush, and Rock Rake (New/Unused) (A59225)
Mini-Excavator...
