Oil & Fuel Trouble Turning Off my John Deere 1050
   / Trouble Turning Off my John Deere 1050 #1
kyhunter
Lexington, KY
JD 1050 2wd with FEL
I just got done replacing the cylinder head gasket on my 1050. I had the head resurfaced. I am now having problems getting the tractor to turn off. Before working on it, I would turn the key to the off position and turn the throttle all the way down and it would stop. Now I have to mess with it for a while in order to get it to turn off. Any suggestions? Is the engine suppose to turn off when you turn the key off? This is a 3-cylinder diesel.
   / Trouble Turning Off my John Deere 1050 #2
You turn it off with the throttle.Make sure the foot throttle isn't sticking.If you have to,adjust the linkage.If you don't turn off the key,the battery will run down.
   / Trouble Turning Off my John Deere 1050 #3
I had a problem with my JD750 not shutting off. It turned out to be the foot throttle sticking, which prevents turning the throttle all the way down.
Thanks guys. I will give that a shot.
Frontier RC2084 3Pt 7' Mower (A47307)
Frontier RC2084...
2008 John Deere 9570 STS Combine  Front Duals  Premium Cab  1,704 Sep Hours  Clean & Field-Ready (A48561)
2008 John Deere...
2015 MACK CXU613 TANDEM AXLE SLEEPER TRUCK (A45677)
2015 MACK CXU613...
2022 FORD F-150(INOPERABLE) (A47001)
2022 FORD...
2016 John Deere 6155M (A47307)
2016 John Deere...
2005 Ford F-150 Ext. Cab Pickup Truck (A46684)
2005 Ford F-150...
