troubleshooting 1948 8N
   / troubleshooting 1948 8N #11
or it could be incorrect resistor.. or it could be a failed condensor.. or bd wireing.
you need to do more troubleshooting before buying stuff. throwing parts atr a problem you don't fully understand MIGHT get you lucky.. or it might waste money.
i'd check out all the wire connections..and put a test lamp in line with coil and bump over and see if lamp blinks good.
Ok thanks. I gotten to know this tractor pretty well now. I'll get back to you with my findings.
Was the coil. Spark wasn't strong enough. It needs some serious tuning now since the guys of the carb are new.
   / troubleshooting 1948 8N #15
I got mine figured out, its amazing what you can get accomplished with a little time. I changed the plugs, gas, sediment bowl and screen, gave it a good shot of starting fluid and she started for me. The carb could use a good cleaning I assume since it runs best with the choke out ever so slightly. I was going to check the compression but it fired over so I'll wait to check that until I get it in the shop where its WARM. Thanks to all who responded!
It's running, but runs like ****..... Need to take apart the carb again to check float and any obstructions.
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2006 CHEVROLET EXPRESS SERVICE VAN (A54313)
2006 CHEVROLET...
2010 DODGE RAM 2500 FLATBED TRUCK (A51247)
2010 DODGE RAM...
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
1839 (A51248)
1839 (A51248)
