troubleshooting charging system
   / troubleshooting charging system
Ouch! that would stink! but the orig. battery would not hold a charge very well even on the battery charger, so it was probably bad. It would charge up pretty quick, and then seemed to die in 3-4 days. The new Optima at least seemed to hold the charge for 2-3 weeks.
Latest update. It appears to be charging now. I bought a $3 voltmeter from Harbor Freight (on sale.. get one for each room of the house!!) Switch off was 12v DC or just under. Engine running was 12.5-14V and with my clamp on current gun, I see 5-10 amps on the wire. If I unplug the alternator, there is no amperage on the wire. So.. I'm cautiously optimistic that the problem was a bad connection somewhere. The Vs fluctuate as the battery charges.. which I presume is the role of the rectifier/regulator. Now the big task is my engine overhaul.. under a seperate thread here.
A huge thanks for all the advice.. even if it was not used this go-around, it will come in handy down the road I'm sure. Tractors get a lot dirtier than cars.. so I guess the lesson is that dirty/corroded connections can be a real problem.
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
New Holland T2420 (A53317)
New Holland T2420...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
Portable Restroom (A54865)
Portable Restroom...
Galvanized steel fence (A53424)
Galvanized steel...
