Troubleshooting trailer ground (weak brakes)
   / Troubleshooting trailer ground (weak brakes) #61
Glad you got it fixed. Now you have a spare magnet for the future.
What was the verdict on your Dodge Controller? Did you ever get it checked out/reprogrammed by the dealer?
Chris
Indeed. And I know where the zerks are for greasing my bearings. And I've got valuable troubleshooting experience. I don't know how I missed that the wire was broke.
Actually, now that I think about it, I do. For whatever reason, the leads coming from the brakes are tied in an overhand knot. The break in the wire was up-stream of that knot, which meant when I was handling them, I never noticed that one was loose.
I have not even looked into that yet, to tell you the truth. I've been busy with a million other things, and it's only the magnet coming in the mail that got me thinking about this again.
- Lube or repack every 12 months or 12,000 miles
Do you think that this means to take out the bearings, clean them out, and hand-pack them? Or can I just squirt more grease into the zerks on the axle?
   / Troubleshooting trailer ground (weak brakes) #65
From the way it is described on page 56 of the link I posted, at least with Dexter EZ Lube axle, yes(squirt more grease in). They indicate as you squirt more grease in, it will push the old grease out around the zerk fitting. Then you wipe the old stuff out of the cap area when you see the new grease coming out.
That page 56 has a good diagram showing how it works.
   / Troubleshooting trailer ground (weak brakes) #66
That is where an Amp Clamp is nice. Clamp on amp meter just goes over the wire.
Funny, this post made me think of that. I did not even think to use it a year ago when I had brake issues on my 5th wheel; it was just sitting in the toolbox...
   / Troubleshooting trailer ground (weak brakes) #67
I haven't seen the Dexter design, it may have better seals than most.
BUT, be conscious of the issue of over-greasing with a grease gun. On some trailers, it is pretty easy to push grease past a basic seal and flood the shoes with grease.
Shoes and hardware will last a very long time with grease in there, and will be nice and quiet, but that is not what most of us want/need !
Rgds, D.
   / Troubleshooting trailer ground (weak brakes) #68
My wife doesn't like it when I have a stripper, much less two, even if they did just graduate :)
And we don't either if your not sharing!!:D
   / Troubleshooting trailer ground (weak brakes) #69
In the earlier link I posted, Dexter warns not to use a pneumatic grease gun, 'cause they will blow grease past the seals too easily.
I have a hand-pumped grease gun. I checked my axle owner's manual that came with the trailer, and it says that my trailer may have "Accu-lube" hubs, with zerks and rubber caps on the dust covers. It has all those things, which suggests I should be able to just pump new grease in until the old grease comes out. But then again, it also says the Accu-lube hubs should have a flat lock washer on the castle nut, but I have a cotter pin.
I think the presence of the zerks is pretty definitive, and that's probably how I'll change the grease going forward. Presumably, it's designed for use with a grease gun, right? Seems kind of dumb if they design them to be lubed through the zerk, but you can't do it due to overpressure concerns.
   / Troubleshooting trailer ground (weak brakes) #71
Think of this as "access point" vs. "appropriate amount".
Ex. You access the oil fill point on a engine by taking a cap off. How much do you put in ? 3L, 5L, 14L.... ? Not saying anything about your work/skills, just have seen crankcases, tranis.... overfilled. And... these are cavities that usually have dipsticks (not trying to be funny ;) ).
If the bearings were packed properly to begin with, you'd likely only need a couple of pumps at the most once a year, unless you put on crazy
high mileage.
Even a hand pump grease gun can put out pretty high pressure, and can easily overcome many basic seals on these type of wheels.
I expect a good design from Dexter; they may have taken a design approach that is less susceptible to ove-rgreasing - just saying it may not be immune.
Once the shoes are saturated with grease, you just toss 'em, and have to spend time degreasing most of the mechanical - usually faster to just replace the whole brake assembly. I just had to do this, on an old travel trailer I bought in Dec.
Rgds, D.
   / Troubleshooting trailer ground (weak brakes) #72
Well, it's always nice to know the next time I'm bored, I can come up with something to do. At least it's a job I have the skills for (wiring). What's the best way to do those splices? I can pull out a soldering iron if I need to.
I would avoid soldering like the plague.
I used to work for a company that supplied electrical connectors to the auto and truck market. Soldering will always fail in time.
The problem is that the hot solder wicks up the strands of the wire and stiffens it. This produces a stress concentration at the end of the solder wick part of the wire and it will fail under vibration at that point.
The very best connectors are properly applied crimp connectors. In a factory setting a calibrated crimp head will always make a very good connection. This is hard to do in the field, but the closest you can come is to use good quality crimp connectors and one of the crimpers that looks like a pair of pliers.
Avoid the ones that are made out of heavy gauge sheet metal and are combination wire strippers/crimpers.
   / Troubleshooting trailer ground (weak brakes) #73
In general, a clamp on ammeter will only work on AC current.
In order to get one that works on DC, like a vehicle has, you need a "Hall Effect Ammeter". These are not easy on the wallet. Even inexpensive ones start at ~$250 and they go up from there.
Essentially, if you have one, you know it and know how to to use it.
   / Troubleshooting trailer ground (weak brakes) #74
Unless you live in Arizona, or some other desert, most connectors (including crimp) will really benefit from a moisture barrier.
Some recent crimp connectors have silicone built into the heatshrink layer. A bit messier solution is to get out a tube of silicone to seal up standard crimps and other connectors - I've done it often.
Marine spec grease is great for repelling water, but even a basic lithium grease liberally applied to electrical connections helps a lot. Corrosion is prevented, and the connections will still be serviceable/useable if you are dealing with removable connectors.
Rgds, D.
   / Troubleshooting trailer ground (weak brakes) #75
I installed my brake controller by putting crimp disconnects on the vehicle's 4 wires under the dash, and the opposite gender crimp disconnects on the fan-out from the TBC connector. The parts were Amphenol and the package said something like "amp disconnect" and a wire gauge. Is that what you mean?
The reason I did the TBC that way was so it would be easy to remove or change in the future.
I have started replacing skotchlok connections on my trailer with solder and heat shrink. I thought this would be the best way. Are you suggesting I do something else? I could buy a box with terminal strips and run everything into it, using crimp-ons on the wires. Will it really last longer? I guess it would be easier to troubleshoot.
Interesting. Crimped-on wire nuts were what the manufacturer used. Some of them had already fallen off. I twisted the wires together and then heat-shrinked the connection. I checked the other connections. Of the eight such connections on the trailer, two had already fallen off, four came off easily when I pulled on them, and the last two were pretty darn secure, but I pulled them off and heat-shrinked them anyway, because at that point, I had done all the other ones and I was going to do this one too! :D
Good point about the solder. I never thought of it that way.
   / Troubleshooting trailer ground (weak brakes) #77
Aw, now just go and burst my bubble :D
The one in the garage is AC...
The one at work is hall effect, and was expensive.
The others at work are hall effect, but are pcboard mounted... Use to measure individual rails going from a PC power supply to the motherboard.
And the other one, is a Tektronix, and goes on an o'scope. It is accurate to a milliamp.
   / Troubleshooting trailer ground (weak brakes) #78
What in the world is a "crimped-on wire nut"?
A wire nut has a spiral spring in it and is wound onto the wire. A crimped connector has the wire inserted straight in and is then crimped on.
I have never seen or heard of a crimped-on wire nut. The spiral spring would resist crimping...
   / Troubleshooting trailer ground (weak brakes) #79
They just look like a wirenut but are crimp on. You simply twist the wires and the put it on like a wire nut and then a crimp to really secure it. If crimped properly they will make a very secure connection. The problem is most do not use a proper set of crimps.
Chris
   / Troubleshooting trailer ground (weak brakes) #80
While Dave is right that solder creates a stress concentration at the point where the solder ends, I find it to be a trade off between corrosion (especially where salt is used) and vibration breakage. My method is to solder but to attach the wire in the unsoldered section to the frame with a P shaped stress relief gizmo. I've never had a soldered wire vibrate in two but have had many corrode prior to soldering. My experience, YMMV.
86"X18' DOUBLE AXLE TRAILER (A60430)
86"X18' DOUBLE...
2003 MACK 1M2 DUMP TRUCK (A60430)
2003 MACK 1M2 DUMP...
2018 Toro Sand Pro 5040 Bunker Rake (A59228)
2018 Toro Sand Pro...
PALLET OF (4) SETS OF 18"X78" BIFOLD DOORS (A60432)
PALLET OF (4) SETS...
2017 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A60429)
2017 CATERPILLAR...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
