Truck advice needed. What would you buy?
Status
Not open for further replies.
   / Truck advice needed. What would you buy? #31
As long as we're all strapping our BS hip waders on :D , I'll throw in my .02c. :
No Ford diesel drivetrain has been able to match GM's diesel drivetrain for the last 9 model years. I buy a truck for the engine, transmission & rear.
If I want more suspension, I'd buy a medium duty IH, built by a real truck company. I never felt comfortable pulling a 16K trailer behind a truck that lacked the GCWR, the stopping power or the longevity to do a job like that on a regular basis.
   / Truck advice needed. What would you buy? #32
Oh boy lol, I probably should not jump into this right now, but I am sitting on the couch next to the wife, and she is watching the Lifetime television network, so I guess this is the lesser of the two evils, here goes. Having owned a F350 SD DRW 4x4, and a Dmax, both for almost 100k, I liked the ford cab better, although it had a little less legroom, it was way bigger when it came to width and headroom, it also had more room behind the seat for storage. The chevy cab, although much smaller, seems to be far more air tight at 97 k than the ford was, this advantage is offset by the fact that my chevy currently has no backlighting on the speedometer, gear indicator, oil pressure gauge, voltage gauge, or the left and right temp selectors on the heater control. Ford may build lots of stuff in mexico, but I swear that half of GM's electrical design team are interns straight out of amish country.
As far as trailering is concerned, I will not compare power, since one was gas, and the other is diesel. Suspension wise the ford was about about equal to the chevy, despite the ford being a 350 dually, it only had 5 leafs on the rear springs with no helpers, and sat WAY high in the back as most 99 model year 350's did. The Ford brakes lasted for 60k, but I literaly had to stand on them when towing to slow down, the Chevy has a way better pedal feel, but the brakes last half as long.
Both trucks were good vehicles, but they both had their own quirks, the Ford had 5 IAC motors go bad, 2 4WD selector switches, and 4 hub vacume seals. The Chevy has had 6 steering intermediate shafts, on its 3rd set of rear universals joints, 2nd drivers window regulator, the mentioned dash issues and countless tailight and daytime running light bulbs.
I got rid of the Ford at 98k miles because in needed more than I wanted to put into it, Frontend, tires, hard lines,etc. The Dmax has 97k on it it currently, and pretty much needs everything the Ford did, only reason I am fixing the Chevy rather than trading it is that I am going to try and wait a few years for the big 3 to figure out the emissions on diesels.
Both my Ford and Chevy were purchases that today I am still glad I made, but each truck had its own respective problems that IMO were due to the manif. cutting corners.
   / Truck advice needed. What would you buy? #33
It is going to be REAL interesting to see what shakes out in the next 2 years. I won't be a guinea pig for Ford's new taco diesel, so they're out till at least '11-'12. GM is being rather hushed about the future, although what I have seen looks promising. If Dodge gets the 6.7L settled down, with the Aisin & exhaust brake, that very well might be my next truck.
If the Ford turns out to be a winner, they get an exhaust brake and the others don't match up to Ford, I guess I'll be driving a (removed) again. No problem with that.
Just buy the best truck you can when you're buying. :)
   / Truck advice needed. What would you buy? #34
Just buy the best truck you can when you're buying. :)[/QUOTE]
I am still looking for a brand new Ford 350 4x4 with a common rail 5.9, a 6 speed allison, rockwell transfer case, dana 60 kingpin front, with eaton electric lockers front and rear, and 265 bridgestone Revo's. :D
   / Truck advice needed. What would you buy? #35
No BS waders on for me Builder,:rolleyes: I'm just telling my experiences with me owning and driving and towing the last three diesel pickup trucks. It is what it is and my current F350 does out preform my Dodge Cummins and and my GM Duramax( now government motors) with the Allison.:D
DevilDog
   / Truck advice needed. What would you buy? #36
I have always liked GMC trucks but after the problems I had with my first Duramax Allison I went to a 2003 Ford 6.0 and had almost no trouble with it and the Torqshift was flawless for 160K+ miles. I then tried another Duramax Allison in 2005 and the Allison limped on me almost every time I pulled my 35 gooseneck loaded with hay. I am now in a 2008 SRW F350 with 30,000 miles with 210 hp program in it for 25,000 miles and it has not missed a beat. Maybe I was just unlucky with my two D/A and maybe I have been lucky with both of my Fords, I don稚 know but unless my 08 Ford starts giving me problems my next one will be another Ford.
Builder I may be wrong but I believe the AISIN is only available in the Cab & Chassis models, at lest that is what my local dealer told me and looking at them on the lot side by side they looked different. Also on Dodge痴 web site they only mention the AISIN on the Cab & Chassis but I may be over looking it. I do agree with you on holding out on the new 6.7 Power Stroke for awhile it will have the exhaust brake though but it will not turn off and on like the Dodge it will come on with Tow Haul.
   / Truck advice needed. What would you buy? #37
Builder I may be wrong but I believe the AISIN is only available in the Cab & Chassis models, at lest that is what my local dealer told me and looking at them on the lot side by side they looked different. Also on Dodgeç—´ web site they only mention the AISIN on the Cab & Chassis but I may be over looking it. I do agree with you on holding out on the new 6.7 Power Stroke for awhile it will have the exhaust brake though but it will not turn off and on like the Dodge it will come on with Tow Haul.
You're right, but I am a cab/chassis buyer because I put utility bodies on trucks, so I could get the Aisin in my next truck :) . I have heard nothing but good on the 68RE automatic the put in the pickups. I just read on another website a guy just started having trouble with his after like 265,000 miles. That's unbelievable.
   / Truck advice needed. What would you buy? #38
So one would think that you would have purchased GM trucks for the last 9 years?:D
I had to say it Builder;) Just messin......
   / Truck advice needed. What would you buy? #39
Does Dodge offer Cab & Chassis in any thing other than 4500 and 5500 or is it a bed delete like in the F250 and F350 Fords. If it is a bed delete it would probably have the 68RE.
My Uncle has 6.7 with the 68RE and he likes it a lot. I sold him a few loads of hay, he used my trailer to haul it, and I rode with him on one of the trips, the shifts were good and I liked it a lot. I might look at them if the if the new Power Stroke is a flop. But that will be a few more years.
Status
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2012 International...
Dewalt DWM120 5" Deep Cut Variable Speed Band Saw (A59076)
Dewalt DWM120 5"...
1290 (A58374)
1290 (A58374)
2004 FORD F-650 SUPER DUTY CAB AND CHASSIS (A58214)
2004 FORD F-650...
2013 F-550 Bucket Truck (A55302)
2013 F-550 Bucket...
2002 Henderson 8X Mild X Sandspreader Attachment (A55973)
2002 Henderson 8X...
