Truck Canopy Lift
   / Truck Canopy Lift #1
anojones
WA
JD 3320
Does anyone have any links or ideas to easily remove/store a pick-up canopy? I usually keep mine on my truck, but there are times I'd like to get a load of rock/soil and need it off. I was thinking I might be able to use clamp-on forks on my FEL and build a rack onto the forks that would fit under the canopy to lift it off. Is there a commercial device folks have seen? Thanks for any help.
Aaron
   / Truck Canopy Lift #2
How about for posts pounded into the ground. Back the pickup between them, get in the box and lift one end at a time, slide a beam onto the posts and under the canopy and the repeat at other end.:D
Or else make use of some young strong back! I used to be able to install/remove my truck canopy all by myself with no problems!:D That is no longer the case!:confused: :confused: and I don't know why.:confused: :confused:
   / Truck Canopy Lift
That's my problem as well. :) After thinking about it, I think I'll place a couple of eyebolts on each end of two two by fours- slip them under the canopy near the front and back then use tie-downs hooked to a hoist and lift it off, I can then store it near the ceiling as well. I will have a 12' ceiling in by new barn, so hopefully that will work.
2015 Freightliner Bucket Truck - Terex TM 100 Boom - Cummins Diesel - Allison Transmission (A55218)
2015 Freightliner...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2011 Isuzu (A55788)
2011 Isuzu (A55788)
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
2013 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2013 FREIGHTLINER...
