Truck Leaking Green Liquid - Not Anitfreeze??
   / Truck Leaking Green Liquid - Not Anitfreeze?? #11
Some washer fluid is green, like DP said.
Was plowing my neighbors driveway yesterday while he and his wife were at work, noticed several drips of green fluid on the snow atop his garage pad, texted him with my phone advising him to check under his vehicles, then shoveled the green drips into a trash can in case they were antifreeze coolant, he has a pair of K-9 dogs and the coolant would be poisonous.
Turned out the drips were from his wife filling her cars washer fluid tank with washer antifreeze, but he was really grateful I noticed it and thought enough to let him know it might be a problem or a hazard to his pets.
   / Truck Leaking Green Liquid - Not Anitfreeze?? #12
I guess AC. That is the color of the dye that they put into systems to check for leaks. It shows best with a uz light bit will look green to the eye, a neon green. I get it in the recycler AC machine i have as well as on some of the fittings i have messed with. This is on all my personal stuff, not in the biz. But i did not think they did it at the factory, but i dont have any thing that new and dont keep up with what they do and dont do.
   / Truck Leaking Green Liquid - Not Anitfreeze?? #13
Not sure if your GM has a steering stabilizer or not, but I replaced the one on my F250 with one from o'reilly's a few years back and now it is leaking and it's a green colored oil in it. Just something else to check.
   / Truck Leaking Green Liquid - Not Anitfreeze?? #14
op.. find out anything yet?
   / Truck Leaking Green Liquid - Not Anitfreeze?? #15
While we're still guessing, my air conditioning compressor was leaking in my (brand new) F350 (in 2004) and the liquid was neon green. So, I'm guessing A/C oil also.
   / Truck Leaking Green Liquid - Not Anitfreeze?? #16
I think 905 or better of the dye that they use in the AC system is green. Freon is colorless and oil is clear, the dye is waht colors it and it can be seen with your eye.
   / Truck Leaking Green Liquid - Not Anitfreeze?? #17
is that the uv leak detector dye?
soundguy
   / Truck Leaking Green Liquid - Not Anitfreeze?? #18
soundguy
It's generally green...At least from my experience. A few drips would say that's what it could be, especially with Dex-Cool..If the defroster was run that would pressurize the AC. I'd try snugging up some of the hoses.
   / Truck Leaking Green Liquid - Not Anitfreeze?? #19
might check the schrader calve caps to.. or those qd lines with the lil seals and retainers.. might look for dust collected around one indicating a weeping seal..
soundguy
Thanks guys.
I washed the truck and parked it on fresh snow, letting it idle for about 10 minutes yesterday. No spots.
Been dealing with a leaky roof this weekend and a sick family member, so I haven't had much of a chance to diagnose the truck any further. Haven't drive it much either.
I'll look it over more tonight. I plan on running the A/C and watch for leaks and proper operation. Gotta get it ready for its annual inspection anyway.
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55314)
2023 Kubota...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Adams 16T Tender Body (A55315)
Adams 16T Tender...
72" HYD QUICK ATTACH GRAPPLE (A51406)
72" HYD QUICK...
Club Car Utility Cart (A55853)
Club Car Utility...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
