Trying out a Brush Grubber
   / Trying out a Brush Grubber #11
If you get a tree bigger than you can handle you will slip going backwards, but you can flip over going forward. Just a word of caution.
Thanks for the reminder. I have the box blade mounted & figured I would be running the chain underneath it. If it is lowered to just above grade (the scarifiers aren't down) my assumption is that it should serve as a safety device in regard to the potential for flip-over.
Nick
   / Trying out a Brush Grubber #13
If you google tree shears, they mount on a fel or 3 piont hitch. they look like
a neet toy then you sell it after you are done. No holes,just spray stumps with brush killer. Let me kwow how they work.
   / Trying out a Brush Grubber #14
Thanks for posting this, I have been considering buying one; looks like a good product.
   / Trying out a Brush Grubber #15
I've used mine a few times and it worked fine.
   / Trying out a Brush Grubber #16
has any one tried a tree shear?they look like they would be the ticket, but they wiegh so much. the big 20'' wiegh 2000 lbs, thats getting close to my limit on a deere 5525.
   / Trying out a Brush Grubber #17
The tree-grabber looks cool and may be faster, but I have pulled dozens of little tree's like that with just wrapping the log chain around them 3 or 4 times and hooking it to itself. It rarely slips, it nearly always bites in and yanks them right out.! Of course you need a "groundman" to keep from getting on and off the tractor all day.
James K0UA
   / Trying out a Brush Grubber #18
Is there not a place to put a tractor hook on the bottom of the rear axle? I use a hook on mine and just put the chain on it -- way easier than a drawbar and as low as possible on the tractor from a safety standpoint. Even pulling from the rear I lose traction when pulling spotted alder:eek:
   / Trying out a Brush Grubber #19
I think you might find it more effective if you attach it low on the tree (at ground level) and route your chain up over a wheel or a post notched on top to give you an up pull instead of a sideways pull on the tree For a wheel, look to get yourself an old wooden cable reel or a large steel car or truck wheel from a junkyard. Or just use a 4 x 4 post with a notch cut in the top to guide the chain.
Watch this vid and see how this small lever grubber does it Same principle.
YouTube - Metal-handled Brush Grubber Demonstration
   / Trying out a Brush Grubber #20
The biggest hassle was constantly dismounting & getting back on the tractor.Nick
Yeah this could be a real drag if you have lots of trees to pull out and no ground helper to connect/disconnect.
That's why it think something like this is a good idea
Tractor Forks, Bucket Forks, Loader Forks
Several people on TBN have built similar tools based on the same concept Do a TBN search for "tree getter" and you'll see many good ones
Pallet of 10 Chains and 5 Binders (A54865)
Pallet of 10...
Cat TH407C Telehandler (A53472)
Cat TH407C...
Year: 2007 Make: Freightliner Model: B2 Vehicle Type: Bus Mileage: 282,860 Plate: Body Type: (A55852)
Year: 2007 Make...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A55788)
2019 Ford F-550...
Giyi Tree Boom (A53316)
Giyi Tree Boom...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
