I used my new pump today and I was very pleased. The only complaint I have is that sucker is LOUD!!! Sorta pollutes the quietness of the country......
However, it pumped lots of water in a short period of time. I was very impressed with the amount and pressure of water that it discharged. In fact, I had to start just running it at idle because it was sucking water up faster than water would run into the hole I put it in. This got to be very muddy water, so I pumped some clean water out of my pond before I put it up.
I had to go get some bigger hose clamps before I started. Apparently the 1" spray hose that I got at Tractor Supply was bigger around than they expected, so the clamps that came with the pump wouldn't work. I got a 25' hose and cut about 6' for the discharge and left the big end (about 19') for the uptake (manual says up to 26 feet OK). I put a 1" to 3/4" adapter on the discharge and screwed a water hose on there. It will pump more water out the 1" than it will a water hose, but I had about 80 feet to take the water and I didn't have a 1" hose that long.
The spray hose I got is a little difficult to work with. It wants to coil up all the time, so I found the strainer wanted to hit me in the back of the head everytime I picked it up to move it.
All in all, a good tool I think. I plan to water stuff out of the pond and creek come summertime.
