TSC Fertilizer spreader/2118427
   / TSC Fertilizer spreader/2118427 #1
mscheer772
Hayward Wisconsin
4310 JD 2003
I'm looking at buying the above for my 4310 JD. Does anyone have this spreader?What do you think of it? Can you spread pelletized lime, salt or sand,corn?
Do I need any additional parts to hook up this attachment to my Cat 1 hitch? Any special bushins, etc.?
Help!!! /forums/images/graemlins/cool.gif
   / TSC Fertilizer spreader/2118427 #3
I have a magrix seeder, which for all intents and purposes is an identical unit to that cosmo. The parts breakdown and exploded diagrams for that cosmo was what i used to work onmy magrix.. so the are pert'near same unit.
I've use dmine behind my 27hp ford 8n, and used cat 1-2 bushings and use dit on my ford 5000.
Spreads seed fine.. should spread peletized lime great as well.. corn too.
I imagine sand will spread ok.. but I'd use a lower pto speed, and realize that you will probably get alot of wear and tear spreading sand.
Mine has a good agitator, so i suspect it would do better than average with hi-cal lime or ag lime.. but.. that stuff is just a bear in any hopper spreader..e tc.
All you need is 2 linch pins and your toplink to hookup to a cat 1 tractor...
As always.. check for pto shaft clearance at min / max travel of 3pt..
Soundguy
   / TSC Fertilizer spreader/2118427 #4
Soundguy
   / TSC Fertilizer spreader/2118427 #5
mscheer772.
Please fill out your profile. It makes it easier for people to help you in several aspects. Where are you located! If you are near TN then I would check out the sponsor Carter & Carter here on TBN. They are a lot less $$ if you are not far from TN.
Tom
   / TSC Fertilizer spreader/2118427 #6
mscheer772.
Tom
   / TSC Fertilizer spreader/2118427 #7
I just bought the same thing! I tried to do a little research here, as I always do, but did not find much to go with. I just used it today and I must say I am very peased with it. I find it to be consistent and accurate, as far as I can tell anyway. I just used it to spread fertilizer.
I see that TSC says it holds up to 500 lbs. I was under the impression the one I have will hold 800. I will have to look into that tomorow.
How much are looking at paying?
   / TSC Fertilizer spreader/2118427 #8
TTowne66,
Done!!! /forums/images/graemlins/laugh.gif
TTowne66,
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
Towable Light and tower (A55851)
Towable Light and...
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
23169 (A50324)
23169 (A50324)
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
