WH401
Platinum Member
I stayed tubeless on my 3320, no problems here.
I'm trying to avoid cal chloride in my tires. I located a shop that will put Rim Guard in my rear tires (3320 43/16.00-20). I'm told the tires will hold about 40 gals each and that would add 850 lbs or so. (cost about $3.00 / gal installed = $240 pr.)
Question: Should I stay with tubeless tires or add tubes with Rim Guard? My plan is to stay tubeless at this point.....but I wonder what others do?
radioman said:Yeah GO tubeless. I would replace the stems the same time you put rimguard in. Makes it last longer run unless the machine is practically new.
